It is currently Mon May 11, 2026 5:53 pm
 Post subject: torsion bar problem
PostPosted: Sun Jul 10, 2005 10:15 pm
does anyone know how to get the tension from the torsion bar off of the lower control arm? i broke the heads off of the old adjuster bolts and cant figure out a way to get them out. thanks.
1975 plymouth scamp
PostPosted: Sun Jul 10, 2005 10:31 pm
With the wheels in the air, get an impact gun or big breaker bar if you have room and loosen the LCA pivot bolt.
Or take a sawzall through the bar if you don't care about it and want to replace it anyway. Keep some oil handly for the blade, and a few spare blades while your at it if you take this approach.
Lets see what else... If the adjustment bolt is low enough and the end is exposed past the bottom of the lca, then you can weld some long metal stock to it for leverage then use some elbow grease.
 Post subject: Re: torsion bar problem
PostPosted: Mon Jul 11, 2005 5:16 am
You will need to use a cutting torch on the remains of the adjuster bolt now. Go through the hole in the front of the LCA and cut off the bolt on top of the "nut". You already twisted off the bolt heads and need new bolts anyway.
Just be sure to jack up and support the front of the car first. If you don't, the car will fall down on top of you when you cut off the adjuster bolts.
PostPosted: Mon Jul 11, 2005 10:05 am
Won't the bolt be too mangled to remove and replace if you cut the top off with a torch?
PostPosted: Mon Jul 11, 2005 10:56 am
It does not matter how mangled it is, he already twisted off the other end.
Plus when you buy a new bolt it comes with the rectangular part it threads in to.
PostPosted: Mon Jul 11, 2005 11:10 am
ok thanks ill try those.
1975 plymouth scamp
PostPosted: Tue Jul 12, 2005 12:36 pm
i was wondering where can i get new bolt with the rectangle it threads through? thanks
1975 plymouth scamp
PostPosted: Tue Jul 12, 2005 2:42 pm
http://www.justsuspension.com/
$29.95 each.
They also have an ad in Mopar Muscle.
VM
PostPosted: Tue Jul 12, 2005 3:41 pm
$29.95 each.
VM
The price sure has gone up. I bought one from my local Chrysler dealer 15 or 20 years ago and it was only $9.
I'd go check a Chrysler dealer just to compare price. The two pieces come together as a set.
PostPosted: Sun Jul 17, 2005 3:24 pm
Site Admin
Speaking of trouble removing Torsion Bars....
I'm making an afternoon of pulling the /6 bars to install a set of V8 bars DusterIdiot found for me.
I've got the adjusters removed, the clips out, and the bar seals off and slid forward on the bars. I've cleaned out the rear clip pockets, and liberally doused the LCA with liquid wrench.
The old bars will not move. I started out with a Ball-peen hammer. Now I'm up to a 2 1/2# Sledge. They won't move. I'm about to take my propane torch to the LCA.
Any thoughts?
CJ
PostPosted: Sun Jul 17, 2005 3:30 pm
If so, then I would suggest prying between the front of the LCA, or gently hammer the bearing/bolt on the front. This is in a direct line with the torsion bars, and will push them backwards.
PostPosted: Sun Jul 17, 2005 3:39 pm
Site Admin
Will do. Starting to run out of steam.
Is this an alignment problem, where the LCA rake angle is off? Sorry, caster? Too many years working on MC's... What I am hearing is to put a bar in the LCA and attempt to move it forward to release the Torsion Bar.
CJ
