It is currently Tue May 05, 2026 1:42 am
 Post subject: UCA bushings
PostPosted: Sun Jul 17, 2005 4:13 pm
How do I torque the UCA bushings with the tire on ?
I was told to toque the UCA bushings AFTER I set the ride height and while the car was on the groud. This prevents the bushings from being "clocked".
There is no room to get a torque wrench in there, however.
All that I can think of is to put the car on a jack stand and then jack up the LCA so that it is in the same postion as when the car is on the ground.
Thanks
PostPosted: Sun Jul 17, 2005 8:31 pm
Jack on the LCA with the wheel off works. You can also use a reg wrench to partially torque them with the car on the ground, then jack up and torque. I never use a torque wrench, FWIW, just crank em.
PostPosted: Sun Jul 17, 2005 10:39 pm
Thank you, sir.
