It is currently Mon May 11, 2026 11:48 pm
 Post subject: Custom Intake Manifold
PostPosted: Thu Jul 14, 2005 8:46 pm
Ok, I got this crazy idea since evening, how good is the idea of making 2 intake manifolds, this manifolds will carry a single bbl carb and will feed the 3 front cylinders and the other to feed the remaining cylinders. What do you think?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Fri Jul 15, 2005 7:34 am
Offenhauser already makes that manifold. So does Lynx.
PostPosted: Fri Jul 15, 2005 9:36 am
Ok SSDan but cost, shipping and taxes to get a manifold to me here in Mexico makes a total amount of 600 dollars, thats a hell of a lot money here, for that amount I can paint my whole car and get new seats and new audio.
So I will take your answer as a yes.
Valiant Duster 1971
PostPosted: Sat Jul 16, 2005 1:51 pm
I believe one plenum manifold might work better since you will need some form of heat for street use. I'm in the process of making one now using some old existing intakes. I will use water heat at the bottom of the plenum.
PostPosted: Sat Jul 16, 2005 4:23 pm
So where did you put the 2nd fuel tank for the premium (or is it 2nd & 3rd so each carb gets a tank)
And how badly does it run when only 1 of the fuel tanks runs out of gas??????????
PostPosted: Sat Jul 16, 2005 6:30 pm
I will need a heat source for my twin manifolds? other than exhaust manifolds?
Valiant Duster 1971
PostPosted: Sun Jul 17, 2005 3:25 pm
What size of pipe is being used in that manifold?
PostPosted: Sun Jul 17, 2005 9:21 pm
I.D. is 1-9/16"
PostPosted: Mon Jul 18, 2005 8:36 pm
And the O.D. would be?
Users browsing this forum: Bing [Bot] and 18 guests
