It is currently Tue Dec 30, 2025 3:22 am
 Post subject: RV cam?
PostPosted: Thu Jul 28, 2005 4:13 pm
What would an RV cam compare numerically to say something like Clifford's 260/264/etc? I've heard it's for low end torque and better fuel economy, is it a decent cam for a forced induction motor with stock internals and the four barrel TBI I've got on?
My car may be slow to sixty, but at least it's been reliably slow to sixty for more than thirty years.
PostPosted: Thu Jul 28, 2005 4:56 pm
"RV cam" doesn't refer to any specific camshaft. It's a term that's been used in the past to refer to a cam that's ground so as to promote low-end torque rather than high-RPM zoot. In general, that means short duration, medium lift and relatively low overlap, but most of the cams that have been on the market for the slant-6 have more overlap than you'd tend to want with forced induction. If I were running a supercharger or a turbocharger, I'd be mighty tempted to start out with the stock '60-'64 cam (232° intake, 228° exhaust, 0.365" lift and 8° overlap).
PostPosted: Fri Jul 29, 2005 9:28 am
True - unless you know exactly what's going on in the motor, the stock cam is a safe choice and for street use not very much power from new cam that you can't get with boost.
PostPosted: Fri Jul 29, 2005 9:41 am
Thanks Dan/Panic
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
