It is currently Sun May 03, 2026 6:54 am
 Post subject: uca bushing replacement
PostPosted: Fri Jul 29, 2005 10:22 am
It's about time for new tires on the front of my valiant (choppy, lumpy, and wearing on the inside). Before spending money on tires I would like to align the front end. Yesterday I pulled the car into the shop put it on a lift and said a little prayer to the god of rusty bolts. The first cam bolt I tried turned relatively easily. The second bolt is frozen solid. The suspension is original 1965 and I expected the bolts to be rusted to the inner shell but is there an easy way to remove the bolts. The last time I did this I had to cut the bolts off with a grinder. I also know that a sawzall does not much more than make noise against these bolts. I definately want to stay away from the torch. Any suggestions.
PostPosted: Fri Jul 29, 2005 11:11 am
Soak it in PB Blaster. Spray it on and let it soak in. The suspension bolts on my '64 came off with no real problem.
 Post subject: bolts
PostPosted: Tue Aug 02, 2005 9:56 am
Despite lots of penetrating oil and patience, my adjusting bolt eventually just snapped off and I ended up cutting through the saddle with a Dremel 409 disk. That worked, but was slow going.
