It is currently Sat May 09, 2026 11:32 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Sun Aug 07, 2005 5:41 am
There is your problem. Someone changed out the rear, at one time to the small bolt pattern drum brake unit, or did a disc brake conversion. What you will need to do, to get the same bolt pattern, front and back, is to change the rear, to a 7 1/4 from a disc brake "A" body, or convert to a 8 1/4 rear.
PostPosted: Mon Aug 08, 2005 4:51 pm
what size is the small bolt pattern? a 8 1/4 will bolt right in pretty much??
PostPosted: Tue Aug 09, 2005 5:37 am
The large bolt pattern is a 4 1/2 inch bolt pattern. The small is 4 inch bolt pattern. A 8 1/4 rear from an "A" body will bolt in, be will need a shorter driveshaft. Take a look here.
http://www.slantsix.org/forum/viewtopic ... highlight=
PostPosted: Tue Aug 09, 2005 7:02 am
metric bolt pattern???
5 x 100 mm. Almost, but not quite, the same as 5 x 4". The offset is usually wrong, too.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Aug 09, 2005 7:27 am
Car Model: Valiant V200 225 4dr three on the tree
5x100 = Toyota Camry -91
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Tue Aug 09, 2005 11:38 pm
wow
PostPosted: Wed Aug 10, 2005 6:57 am
Just to restate: I would not use the 100 mm wheels, except as a spare.
 Post subject: confusing this is
PostPosted: Wed Aug 10, 2005 7:11 pm
of coarse.
