It is currently Fri Nov 20, 2026 1:31 am
 Post subject: lokar- push or pull???
PostPosted: Wed Aug 17, 2005 5:23 pm
just got my new lokar cable for my tranny kickdown. question-can it be set up to "push" kickdown lever on trans, or is it strictly a "pull" cable setup? i know alot of you guys are using this on your slants...thnx, steve
PostPosted: Wed Aug 17, 2005 6:54 pm
Pull, I can't see how it would be stiff enough to push the lever on the trans...
70 Dart, 360, 727
PostPosted: Sat Aug 20, 2005 11:50 am
It can only pull. It's sort of like a second throttle cable - in fact, mine is attached to the gas pedal like it's another throttle.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
