It is currently Fri Nov 20, 2026 12:21 am
 Post subject: fuel tank leak
PostPosted: Sun Aug 21, 2005 2:22 pm
my fuel tank had a little drip coming out of the sending unit when the tank was full. so i figured the old gasket had rotted and like a responsible owner i ordered a new gasket and metal sealing ring from year one.
installed both, tapped the sealing ring around until the flange on it reached the bump and would no longer turn.
when i filled her up there wasn't a drip, fuel poured out of that thing. i think i caught 4 or 5 gallons before the pressure eased and she stopped. should i use gasket sealer? if so what color? i have a 75 but the catalogue said those parts were used on all mopars of the 70s and should fit any vehicle. any advice? im just putting in 4 gallons at a time which means i stop for gas a LOT!
PostPosted: Sun Aug 21, 2005 2:32 pm
Its probably not the fuel sending unit seal. On the sending unit itself, where the metal line meets the circle of the sending unit, this is just a crimp connection that will bust loose if you aren't careful when pulling the hose off the sender. Mine was leaking here too, had to remove the sending unit hand have the crimp tig'd together to stop the leak.
Make sure the rubber line isn't cracked and the hose clamp is nice and tight too. I like using efi hose clamps instead of worm drive clamps
PostPosted: Sun Aug 21, 2005 4:20 pm
While you're in there, think about replacing the filler grommet, too. Mine went away, and it was ugly. I did get to meet a Mopar fan - He came in the fire truck that came to watch my car leak. :oops:
PostPosted: Mon Aug 22, 2005 8:05 am
filler grommet is new, and im sure you can relate when i say squeezing that filler tube through it to get the tank mounted back was a bear.
someone had recommended that i use dish soap as a lubricant on that job. it seemed to help. does that jive with you diy professionals out there?
PostPosted: Sat Nov 05, 2005 10:15 pm
I now have a leak at the fuel guage post, just as you indicated. Who/ how did you recrimp yours? Year One wants $100 for a new sender unit!
God took you away, then brought you back to me.
PostPosted: Sun Nov 06, 2005 9:57 am
You will find that Year One is an overpriced source of many parts that can be had more economically elsewhere. The fuel gauge sender assembly not only is still available from your dealer (4051-006) but is still available in the aftermarket.
PostPosted: Sun Nov 06, 2005 9:43 pm
SSDan, do you have a deep voice, because the voice of authority should be a baritone. High priced merchants and half assed mechanics beware...
PostPosted: Mon Nov 07, 2005 2:05 am
Check rockauto.com they have the spectra (sp?) brand units for a good price last I remember.
I didn't have mine recrimped, I had mine tig welded. Tigs are neat, especially for small delicate work. Didn't cost me anything because the welder was a friend of a friend sort of thing. Couldn't imagine it costing much at a shop though as it takes a whopping 5 minutes or so at the most.
Users browsing this forum: Bing [Bot] and 8 guests
