It is currently Wed May 20, 2026 8:33 am
 Post subject: Stroker 170?
PostPosted: Sun Aug 21, 2005 1:12 pm
Hello everyone! Has anybody tested the stroker 170? I don't remember what site it was on but it's one of the big ones about /6.
So it supposed to be a 170 with a 198Crankshaft. Should do 210CI at the end of the day.
Did anybody try this before? Sounds great but i'd like to know more about it.
Thanks for your answers.
Marc
PostPosted: Sun Aug 21, 2005 2:44 pm
It has been done. Pretty sure Doc Dodge has one. But for the life of, I don't see a lot of reason to do it. If you take a 198 motor and bore it the same as the 170, you get the same cubes. A 225 is bigger yet, with a comparable bore. There is a small weight saving with a 210 low blck as compared to a 210 tall block. The only other reason, I can see to use the 170 block, would be to tell everyone you are running a 170, when you really have much more (can you say cheat).
PostPosted: Sun Aug 21, 2005 2:48 pm
Maybe I'm misreading you, but this doesn't make sense to me. All slant-6s came from the factory with a 3.40" bore.
PostPosted: Sun Aug 21, 2005 4:19 pm
I think Doc has a 260 CID stroker 225... not 170. You can't really add that much by stroking and overboring a 170.... that would be a 198 or a 225. What you can do is use 198 connecting rods on a 225 but that would make less displacement. I don't understand Charlie_S's post... I understand that /6 where fixed bore diffrent strokes and block height for diffrent displacement. (You can say: Dan's right... :lol: )
Juan Ignacio Caino
PostPosted: Sun Aug 21, 2005 4:54 pm
Rod length has nothing to do with displacement.
198 crank in 170 using 170 rods will shorten the rod ratio from 1.925-1 to 1.568-1 - don't know why you would want to do that.
PostPosted: Mon Aug 22, 2005 3:40 am
Docs strokers:
http://www.slantsix.org/articles/stroking/stroking.htm
http://www.slantsix.org/forum/viewtopic.php?t=26
PostPosted: Mon Aug 22, 2005 4:43 am
Sorry, let me clarify what I meant.
If you take a 170 block and bore it to 3.5, and use the 198 crank, you get the same cubes as a 198/225 block bored to 3.5, with a 198 crank. Since the cubes are the same, why would you want to spend the time and money to do this. A 198/225 block bored to 3.5 and a 225 crank is more cubes.
PostPosted: Mon Aug 22, 2005 8:48 pm
now I understand
didn't understand panic's post neither.... maybe I'm reading too fast or my brains' dead...
Juan Ignacio Caino
PostPosted: Mon Aug 22, 2005 11:45 pm
198 stroke 3.625" with 7" 198 rod, rod ratio 1.925
198 stroke 3.625" with 5,7" 170 rod, rod ratio 1.568.
Bigger the ratio is, is better = longer rod is better. Helps the engine rev more freely at upper rpm. And reduces engine wear.
 Post subject: ...
PostPosted: Tue Aug 23, 2005 8:52 am
The other thing Panic was pointing out was the displacement is
not dependent on the rod length - displacement is a function of the
crank throw and the cylinder bore.
PostPosted: Tue Aug 23, 2005 1:55 pm
Thank you all for all these infos! Well, i understood that i'd better go with a 198 and rebore it or even a 225 rather than messin' with my 170. Am I wrong?
PostPosted: Tue Aug 23, 2005 2:13 pm
Doug had a 210 in the Barracuda race car that got wrecked. IIRC it ran low 14's on moder and 12:97 on da joos. :shock:
PostPosted: Tue Aug 23, 2005 3:07 pm
It will be less expensive to build a 225 to a given power level, then a 170. Also you will be able to use "off the shelf" headers, since no one makes headers for the 170, any longer.
PostPosted: Tue Aug 23, 2005 6:44 pm
If you're going to the trouble and expense of swapping the engine, don't mess with the rare and hard-to-find 198. The only reason to like the 198 is that it came with extra-long connecting rods that work well in high-performance 225 buildups. It may be strategic for you to keep your 170 (2,8 litre) engine with French taxes and gasoline prices. There's a lot you can do to make it run better...
PostPosted: Tue Aug 23, 2005 9:19 pm
Car Model: 1964 Valiant
The 1.93 rod ratio with the 7" rods is like Formula 1 spec, supposedly 2.0 is ideal, I'm told, although some OEM Hondas are only around 1.48
What would be the rod ratio be with a 170 crankshaft in a 225 block, assuming you could find custom pistons/rods to allow for the OEM compression height ?
No reason to do destroke a 225, just wondering what the numbers might be.
