It is currently Sun Oct 11, 2026 11:51 am
 Post subject: Need Radiator Quick!!
PostPosted: Wed Aug 24, 2005 7:48 am
:cry: HELP!! Had a very heinous accident with my 65 D100, and need to find a replacement radiator. Is there anything I can do??
PostPosted: Wed Aug 24, 2005 9:31 am
Question people, A Concorde´s /Intrepid 93 or 94 radiator, will work for a slant?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Wed Aug 24, 2005 11:49 am
Trucks tend to be easier candidates for non-original radiator swaps than cars, 'cause there's so much more metal surface to work with.
Just about any later Dodge truck radiator ought to be easily adaptible to your truck. If you can bolt it up, it'll work! What are the dimensions (height and width) of your present (destroyed) radiator?
 Post subject: lots of radiators fit
PostPosted: Wed Aug 24, 2005 6:21 pm
Hello cushing,
In years of radiator collecting for my '64 d100, I found that most all dodge radiators in the same general vintage work, i.e from 64 to 77, d100, w100, 200, 300...while the bigger trucks have more flange and a shroud, they still can just bolt right in with only a few hole re-drills if needed on flanges. If you get one, in my opinion it is well worth the $10 bucks a shop will charge to pressure test it before you put install it. Reason is you can mark its leaks, take it home and either braze or silver solder the leaks and KNOW you are good to ride.
rock
'64d100
PostPosted: Wed Aug 24, 2005 6:46 pm
Do you need an auto or manual tranny type radiator? I have a manual thats been sitting for some time in good condition out of a 77 D100 half ton. Your if you want it, make an offer. My zip is 28547, for shipping purposes.
85 Ram /6
05 Magnum Hemi
71 Satellite 318
 Post subject: Thanks for the Info
PostPosted: Sun Aug 28, 2005 11:54 am
:D Thanks for the info, I'll taake the radiator around here to find out if there is something I can use. You guys are awesome!!
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
