It is currently Fri Jun 12, 2026 12:00 pm
PostPosted: Fri Sep 02, 2005 6:06 pm
hey hows it goin guys i was looking up my other vin number on my other car 2 dr duster hard top and this is what come up do this mean it was made in 1966 thanks
VL29C6G216739 vin#
Model: Plymouth Valiant / Duster
Price Class: Low
Body Type: 2 Door Sports Hardtop
Engine: Special Order 6 CYL
Model Year: 1966
Assemble Plant: St. Louis, MO, USA
Sequence Number: 216739 - 116739th Vehical Built
IS THIS CORRECT thanks for your help guys
PostPosted: Fri Sep 02, 2005 6:30 pm
L29C6G216739 vin#
Use the VIN decoder at http://www.maxwedge.com/ . It's more accurate.
Yeah, sorta, but whoever put together the lookup tables in the VIN decoder you used was lazy. VL29C6 is a '66 Valiant V100 with a special-order slant-6. What does "special order" mean? Well, there aren't a lot of things it can mean in '66. Does the car have factory A/C?
(it's also fun to play with these VIN decoders and put together impossible cars. Put in VH45A9G216739 and see what you get back!)
 Post subject: vin#
PostPosted: Fri Sep 02, 2005 6:37 pm
hey dan thanks for the website this is what it said for the vin# thanks
VL29C6G216739
This vehicle is a 1966 Plymouth Valiant V-100
2-door Sports Hardtop,
Special Order 6 engine
and was the 116,739th car scheduled for production at the
St. Louis, MO assembly plant.
 Post subject: Ac
PostPosted: Fri Sep 02, 2005 6:38 pm
it has no ac thanks
PostPosted: Fri Sep 02, 2005 6:52 pm
Well, the only nonstandard slant-6s available in '66 were heavy- and extraheavy-duty (which went mostly in trucks, though fleets could order heavy-duty engines) and taxi-econo (with smaller/leaner carburetor and different distributor). The export 2bbl setup didn't arrive until '67. So, what's special about your engine?
 Post subject: vin#
PostPosted: Fri Sep 02, 2005 7:34 pm
man i don't know you know anybody who is in the expertise on this car i don't have a clue and i don't know why the engine is a special one might be a vin mistake at the factory don't know ANYBODY KNOW
PostPosted: Fri Sep 02, 2005 10:53 pm
VL29C6G216739 vin#
Bold added to quote. My guess since you said this is a Duster, that it's a 76, which means you need a decoder that covers that year. Here's two I found with a quick Google search:
AutoHobbyDigest Mopar VIN decoder - covers from 1960-88.
Mopar VIN Decoder - has four different decoders covering 1962-65, 1966-74, 1975-80, and 1981+.
Tha AutoHobbyDigest one still indicates it is as special order /6, while the other seems to indicate it's just a regular 225 - maybe you have a Feather Duster?
Steve G.
 Post subject: vin#
PostPosted: Sat Sep 03, 2005 5:53 am
ok here is another decoder this is what it says
VIN VL29C6G216739 decodes as follows:
Description Interpretation Code
Model: Plymouth Valiant V
Price Class: Low L
Body Type: 2 door special coupe 29
Engine: 225ci slant 6 1bbl (RG motor) C
Year: 1976 6
Assembly Plant: St. Louis, MO G
Sequence Number: 216739 216739
and here is another decoder
VIN: VL29C6G216739
YEAR: 1976
MODEL: Duster
BODY: 2 door sports hardtop
PLANT: St. Louis
ENGINE: Special Order Slant Six
DETAIL:
Nth auto@plant: 116738
WARNINGS:
so how come my engine is a special slant six beats me thanks guys for you help
PostPosted: Sat Sep 03, 2005 7:16 am
Oh, lookit that, I completely missed that we were talking about a Duster. Yep, both the VIN decoder you first used and the one I suggested go up to '75 only, AFAIK. And yes, "C" in the 5th digit means a 225 in '76.
PostPosted: Sat Sep 03, 2005 8:26 am
uh oh Dan missed something I think I smell brimstone.
