It is currently Sat May 09, 2026 1:37 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sat Sep 03, 2005 6:31 am
can you tell me where to find the cragar 4" wheels then dan? I can only find 4.5 and up on the site. if they have other designs other than what is on their site I may be interested.
anyone know any other manufacturers for 4" bolt pattern? I am looking for a slightly more modern look, but nothing to space-agey= if that makes any sense.
this will determine if I move up to the bigger pattern or not.
PostPosted: Sat Sep 03, 2005 7:34 am
I bought mine at a wheel-and-tire place in Denver. From what I recall, the 4" bolt circle items are something you have to call Cragar to get.
PostPosted: Sat Sep 03, 2005 9:15 am
Summit Racing has them! Part # CRR-08060 -14x6, 3.5" Backspace. Crr-08070 -14x7 4 1/8" Backspace. CRR-08762 2.75" Backspace. CRR-08762 are the reverse deep dish style and could cause rubbing on the fenders. Centerline also has a 15" wheel in the 4" B.P.
PostPosted: Sat Sep 03, 2005 11:25 pm
Car Model: 1964 Valiant
An adaptor plate can work with the spare tire, in case you have a flat tire, but I'd only use them for an emergency. Assuming you have 4.5" pattern disk brakes on front with the 4" axles on back, with an adaptor you can then carry a single 4.5" spare tire to get you home.
PostPosted: Tue Sep 06, 2005 6:11 am
If you don't mind making the jump to 17's, here's an option:
http://www.coyswheel.com/coys.html
I like the grey version a LOT.
VM
PostPosted: Tue Sep 06, 2005 12:04 pm
thanks guys, I'll have to check on all of this and get back to you....
(went fishing all weekend so I didn't keep up with the posts.........heh he..)
