It is currently Mon Jun 15, 2026 3:07 am
PostPosted: Sun Sep 04, 2005 2:24 am
Got another question!
I actually don't have any ballast resistor in my car. Some friends of mine told me that i don't need it since i have a 12V aftermarket Coil (still old, it's a Ducellier but they told me it would work). Is that true?
PostPosted: Sun Sep 04, 2005 7:58 am
No, it is not true. You need a ballast resistor (also get rid of that Ducellier garbage and put in a real coil), or you will burn up your breaker points again in a hurry.
PostPosted: Sun Sep 04, 2005 12:16 pm
Ok, i'll go to the junkyard and try to find one with the same value (in ohms, it's the only value i should look for?)
PostPosted: Sun Sep 04, 2005 2:35 pm
Skip the junkyard, go to the *parts store*.
