It is currently Mon Nov 23, 2026 11:07 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Sep 13, 2005 8:33 am
Wouldn't a single diode mounted across the ammeter terminals do the same thing?
All the related wiring has been upgraded to 10 ga or better.
It would, assuming that the ammeter itself is the only weak spot. For best protection, I would recommend that the bypass leg (with the diode) ALSO bypass the stock wiring and -especially- the bulkhead connections. In fact, 2 of my old cars had the bulkhead connectors bypassed because they started melting even before putting on the big alternators. IMO Chrysler wiring is NOT particularly poorly designed compared to other makers, but the bulkhead connector is definitely a point that was never expected to last 40 years (and may have been marginal even when new).
