It is currently Mon Nov 23, 2026 6:17 pm
 Post subject: 450 holley carb
PostPosted: Wed Sep 14, 2005 4:53 pm
I've got a few questions here. First, I was wondering if anybody has ever tried a 450 cfm holley on a /6? I am currently running a 390. There are always cheap used 450s on ebay. Second, where can I get a windage tray from?, And finally, I just got a new set of Sealed Power .030 cast pistons, and was wondering if they would hold up to a 100 hp. shot of juice. What about stock rod bolts, will they be strong enough or should I go with a set of ARPs? Any help is greatly appreciated!
PostPosted: Wed Sep 14, 2005 6:17 pm
There will be virtually no difference between a 390 and a 450 Holley. :shock:
The only current source for trays is Mike Jeffrey, and he does not make any more until January or so. 308/324-3576.
Yes, cast pistons will hold up to 100 shot IF your tune-up is good. Lean it out or detonate it and you will eat a piston for sure. Of course, if you do that to a forged piston you'll eat it too.
ARP rod are cheap insurance. :shock:
