It is currently Sat Oct 10, 2026 12:06 am
 Post subject: head bolts
PostPosted: Fri Sep 16, 2005 12:11 pm
I have tried using the parts database and came up empty. I am looking foir a new set of bolts to hold the head to the block, and a new set for the exhaust/manifold (I am using clifford).
anyone know a good place to get new ones?
incedentally, I used to be able to find rod bolt information on the database, I beleive it was written by mr. dutra. I think the article is there but the information isn't in the database (see page http://slantsix.org/articles/ARP-studs/sl6-hardware.htm). seems odd to me.
anyway when saying that "Head Studs : 142 - 4001" does this refer to bolting the head to the block or the manifold to the head?
PostPosted: Fri Sep 16, 2005 8:30 pm
I remember seeing on a website it had Dorman part listing
for various hardware and it showed head bolts.
Try a google search for Dorman.
PostPosted: Sat Sep 17, 2005 12:03 am
napaonline.com, 7/16-14 x 4 3/8" $1.69
Hrumm, 1.69 seems cheap for a bolt that large .....
PostPosted: Mon Sep 19, 2005 12:02 pm
yes it does........makes me wonder about the quality.
thanks for the heads up! I'll tell you if I find anything out.
PostPosted: Mon Sep 19, 2005 2:15 pm
Car Model: '23 T-bucket
I'd be willing to bet the Napa bolts mentioned are standard-duty bolts and are NOT intended for use as head bolts.
Roger
PostPosted: Mon Sep 19, 2005 2:21 pm
They were specifically labeld as head bolts ... I'm not sure what to say thats just what came up when I did a search by application for a 1985 truck.
For the life of me I can't remember where I bought my last set a few years ago.
Hmm, would a shoulderd grade 8 bolt work or is there something special about headbolts?
PostPosted: Mon Sep 19, 2005 8:16 pm
I was lookin the other day... O'Reilly has them for something in that same ballpark... I'm wantin to say it was a dorman part. It's not that unreasonable; the fel-pro torque-to-yield items for newer engines (like the 3.8 GM's) bring around $20 a set. If someone needs the dorman # I could find it.
PostPosted: Tue Sep 20, 2005 12:02 pm
any info is always helpful.
PostPosted: Wed Sep 21, 2005 3:17 pm
Ok, looked up head bolts on a 75 dart. Came up w/ Dorman #675-121. According to the book they are 7/16-14X4.375" with a 1-1/8" threaded portion. Head size is 11/16" and they are not torque to yield. Walk-in price is $1.49 each, but the were not easy to get a hold of; only one of our (O'Reilly's) warehouses had them, and they only had one box (of 10).
As for manifold attaching bolts, Dorman 675-094 is great, just about an inch longer. They're not hard to get a hold of at all.
