It is currently Fri May 08, 2026 2:46 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Sun Sep 25, 2005 8:02 am
...are we sprechen Deutsche now?
Given that I'm typing this from Frankfurt...ja!
 Post subject: Converter
PostPosted: Sun Sep 25, 2005 10:40 am
Ok, I'd like to know where is a good source to find a lockup converter,
I need a performance one. Thanks guys...
PostPosted: Sun Sep 25, 2005 9:52 pm
I heard the governor weights in the tail section must be changed with the rest of the guts, which makes sense, at a lower ratio the same engine rpm would achieve a lower output speed, so it would have to shift sooner
PostPosted: Mon Sep 26, 2005 6:28 am
..yeah, but you don't want that with any kinda performance use. Stick with the original weights.
D/W
If it ain't broke, fix it!
 Post subject: original 904??
PostPosted: Mon Sep 26, 2005 2:35 pm
So it seems to me it just maybe best to stick with my 'ol 73 a904??
 Post subject: Re: original 904??
PostPosted: Mon Sep 26, 2005 5:52 pm
Why? The lower first gear can really help get you out of the hole.
D/W
PostPosted: Mon Sep 26, 2005 6:15 pm
Does it really make much difference in a light a body?
Could a converter be a good alternative? :?
I guess the low gears would help a heavy car more...
PostPosted: Mon Sep 26, 2005 11:43 pm
Also, though not the cheapest. Mancini racing carries low gear sets for the 904 for about $180. Could save you some scrounging time and such.
70 Dart, 360, 727
PostPosted: Tue Sep 27, 2005 7:06 pm
Oh ok...Good point taken D/W. I was looking at some lock up converters and noticed they were pretty expensive, so I guess Im juggling my options here...thanks
PostPosted: Tue Sep 27, 2005 8:10 pm
You definitely do NOT want the lock-up converter. Just put the low gears in whatcha got.
D/W
PostPosted: Wed Sep 28, 2005 6:53 am
The use of the low gearset was an economy minded solution to a problem which is already solved by other products. (such as a performance converter)
If you are mostly racing, just get a high stall racing converter. This will get you out of the lights in a hurry with the standard gears.
I don't know where the trade off between performance and street driveability and economy really curves, but I know that the stock converters are leaning heavily to economy.
If you've got the $180 for a mancini gearset, I suggest you instead keep saving and get some better suggestions about what kind of performance converter will stall at a good place for your motor, car, and driving requirements.
I suspect you'll need between $300-$500 for the converter that will really make it zoom! Good Luck!
1980 Aspen 225 super six
