It is currently Tue Nov 17, 2026 5:38 am
PostPosted: Sun Sep 25, 2005 10:06 pm
Hi, I went from a 7.25 rear to a 8.75. I was wondering if anyone has done this and knows the correct driveshaft length when coming from an a-904. Also, is the pinion angle something that is built into the housing, or something that is adjusted with shims between the spring perches? I remember seeing something about it, possibly in a topic or a Mopar Muscle article. The rear I have is supposedly out of a 68 Dart so I don't have to change anything to mount it up.
PostPosted: Mon Sep 26, 2005 3:08 pm
use the search feature please many posts
And yes you will have to change something the u-bolts are different.
PostPosted: Mon Sep 26, 2005 4:09 pm
Don't forget the shock plates
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Sep 27, 2005 12:10 pm
shorten by some where between 1.75 and 2.25. you will find posts supporting each measurement.
