It is currently Sun Nov 22, 2026 12:37 am
 Post subject: Engine weight
PostPosted: Tue Sep 27, 2005 10:31 am
Probably not the first time it's been asked, but what would a 225 slant/6 engine weigh? This would actually be a long block, no intake/exhaust, carb or externals.
Life is good!
 Post subject: Round numbers.
PostPosted: Tue Sep 27, 2005 11:04 am
Shipping on a block with crank and pistions only is 325lb Add in the cam, timing set, oil pump, valve train, damper, and head (bare head is about 80 lb) We'll easily hit 450lb dry without the manifolds give or take.
Not something you want to lift on your own. :wink:
1980 Aspen 225 super six
PostPosted: Tue Sep 27, 2005 4:12 pm
I have weighed almost all the components of a 225 individually - mid 60s-early 70s. Your mileage may vary...
crank - 71-76lbs
rods/pistons - 20-25lbs
block - 165-168lbs
head (complete) - 76-80lbs
cam - about 10lbs
Add in extras like oil pan, valve cover, rocker train, damper, oil pump/pickup, and you're up around 380lbs for a "long blocK." 75-up heads weigh more. Cast crank motors weigh a bit less. Early 60s cranks are as much as 90lbs some have reported.
PostPosted: Tue Sep 27, 2005 5:14 pm
Here are some Mopar engine weights:
http://www.bigblockdart.com/weights/engineweight.shtml
PostPosted: Wed Sep 28, 2005 12:21 pm
Car Model: Valiant V200 225 4dr three on the tree
Slant 6 ---------------------------------------------525
273-340 ------------------------------------------- 525
True?
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Wed Sep 28, 2005 12:35 pm
I get 425-450 complete except flywheel for a slant.
Users browsing this forum: Bing [Bot] and 10 guests
