It is currently Thu Apr 30, 2026 5:55 pm
PostPosted: Sun Sep 25, 2005 6:33 pm
Looking for a higher performance starter that is lighter than stock and will
work with my mopar 6 into 1 header, any suggestions??
PostPosted: Mon Sep 26, 2005 7:10 am
The mini starter used on late 80s and up vans/trucks works great. Any 3.9V6 or V8 starter will work. Wrecking yard is a good source, or rebuilds from parts store.
PostPosted: Tue Sep 27, 2005 7:37 pm
are the bolt pattern and flywheel teeth pattern are the same as a /6???
PostPosted: Tue Sep 27, 2005 8:01 pm
Yep. All V8s (BB and SB), 3.9L V6 and Slant starters will interchange.
PostPosted: Thu Sep 29, 2005 2:01 pm
can of worms here, but which is the lightest and most trustworthy?
PostPosted: Thu Sep 29, 2005 2:04 pm
A handcrank..........................
:twisted:
PostPosted: Wed Oct 05, 2005 12:06 pm
any real responses?
PostPosted: Wed Oct 05, 2005 2:06 pm
The mini starters I mentioned are pretty much all the same (minor heatshield diffs) and are light and reliable. As with any unit, watch quality if you get a rebuild. I have bought mine new from MP sources and have had no problems. They are better than the factory starters in every way, except the cute noise...
PostPosted: Sun Oct 09, 2005 4:05 pm
how much did it cost you?
 Post subject: cost
PostPosted: Sun Oct 09, 2005 4:43 pm
These are either $129.95 or 139.95 from summit racing equipment.
A rebuilt one fom the parts store really isn't much if any bit cheaper.
They weigh a mere 7 pounds vs. the weight of about a 16 or 17 pound
starter if Im not mistaken. I weighed my stock starter and that's about
what I came up with. Thanks again Lou.
PostPosted: Mon Oct 10, 2005 12:08 pm
I havd been using the re-man ones from checker(big wheel rossi at the time) and they were $35, but they only lasted an average of six months when it was a daily driver.
PostPosted: Tue May 02, 2006 3:49 pm
Do the mopar performance starters do good for high compression slant's??
PostPosted: Tue May 02, 2006 4:28 pm
SSRN National Champion
yep got one on mine for four years it is a MOPAR Performance about the same cost. Just do it Thanks Ron Parker :D See you at the Farm
Hell Hath No Wrath Than A Possum Scorned
PostPosted: Sun May 21, 2006 3:22 pm
Car Model: 1974 W100; 72 Dart
they pop up on ebay all the time. i got mine (new) for 79.95....a little less than a year ago. so far, it has cranked a 400, a 360 and my slant.
sb
