It is currently Thu Jun 18, 2026 9:30 pm
 Post subject: dodge dart rims
PostPosted: Tue Oct 11, 2005 6:55 pm
im gettin a 72 dart and it needs rims in order to move it, does anybody know the measurements between lug nuts or what rims will swap with dodge???
thanks alot
PostPosted: Tue Oct 11, 2005 7:03 pm
Well it either has Small Bolt Pattern (SBP) rims or Large Bolt Pattern (LBP)
SBP rims are 5 lugs on 4" circle (5x4")
LBP rims are 5 x 4.5"
Really need to measure the rims.........
Measure from center of 1 lug bolt to outside of an opposite lug bolt and you'll either get 4" or 4.5". Check front and rear as parts may have beens swapped sometime or other
PostPosted: Wed Oct 12, 2005 1:10 am
If nothing have been changed you have the small bolt pattern. 1972 was the last year for that pattern I believe. Dart/Demon and Valiant/Duster rims up to 1972 will fit and Barracuda rims up to 1969.
So you do not have a lot to choose from.
But if changed you have the large pattern. You can put on just about any rim, even the shivvy and f... ones.. phew..
Almost forgot, if you have disc brakes you need to have the 14" rims.
/Kent
PostPosted: Thu Oct 13, 2005 6:19 pm
Nope. 4 wheel drum equipped A body cars could be had til the end of A bodies in 76 and still had 5 on 4 (SBP) My brother had a 76 Feather Duster that came that way.
PostPosted: Fri Oct 14, 2005 8:47 pm
so some 14" rims on a 77 plymouth volare wont work for a 72 dart or will they?? if you cant tell im new to this lol
PostPosted: Sat Oct 15, 2005 3:16 am
Volare/Aspen rims were all LBP. As mentioned aerlier unless it's been changed to late discs and/or 8 & 1/4 rear end, your 72 will take 14inch SBP wheels.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
