It is currently Fri May 08, 2026 10:09 am
PostPosted: Mon Oct 17, 2005 8:28 am
I jacked the rear up on the Ramcharger thinking I could get my rear axle ratio figured out by turning my whell and couting the revolutions on my driveline. I ended up with 1 wheel revolution = 1 3/4 driveshaft revolution. That doesn't seem to work for any realistic ratios I have seen. How can I figure this out without pulling the cover and counting teeth.
It is an 8 1/4"
bwhitejr
PostPosted: Mon Oct 17, 2005 8:47 am
..sure it does. You've got a 3.55:1
You need to turn the wheel twice on an open rear with the opposite wheel held in place - or you can simply multiply *2
D/W
If it ain't broke, fix it!
PostPosted: Mon Oct 17, 2005 9:00 am
Jack up one rear wheel. Mark the tire. If you have an open rear axle, turn the tire [two] complete revolutions (Sure Grip: Just one) while watching the driveshaft and counting U-joint caps. There are four of them per revolution, so I just count the number of U-joint caps that face the ground over the course of two (open) one (suregrip) tire revolution, then divide by four, thus:
16/4 = 4 = 3.91
14/4 = 3-1/2 = 3.54 or 3.55
13/4 = 3-1/4 = 3.21 or 3.23
12/4 = 3 = 2.93 or 2.94
11/4 = 2-3/4 = 2.71 or 2.76
10/4 = 2-1/2 = 2.45
9/4 = 2-1/4 = 2.26
I know that is correct, because I have the build sheet for the vehicle, but why would I multiply by two?
PostPosted: Mon Oct 17, 2005 9:39 am
On my son's I get:
1 wheel revolution = 1 1/2 drive shaft revolution.
The closest ratio to this that I can find is 3.07:1.
Is this correct?
PostPosted: Mon Oct 17, 2005 9:43 am
On my son's I get:
Is this correct?
No, it is not; there's no such ratio as 3.07.
Again: Rotate the wheel through two revolutions.
PostPosted: Mon Oct 17, 2005 2:23 pm
Because the opposite wheel isn't turning.
Due to the differential, if one wheel isn't turning, the other wheel rotates twice as much........
Note: with a sure-grip, you'll need both wheels off the ground, and both wheels will turn together.
PostPosted: Mon Oct 17, 2005 3:49 pm
THANK YOU! Very succinct way to put it. I think there ought to be a "fundamental basic FAQ" section here to answer these kinds of things.
D/W
