It is currently Thu May 07, 2026 4:30 am
 Post subject: Shift rpm???
PostPosted: Fri Sep 16, 2005 4:57 pm
I don´t race, but I was wondering anyway...
Do you shift at the same rpm in every gear?
I had a little test last week in the truck at work, and it goes a lot faster if I almost peg the tach in the first gears, and go to a lower shift rpm in the taller gears :?
Guess big diesel lowend torque has something to do with it, but anyway...
PostPosted: Fri Sep 16, 2005 5:00 pm
Shift RPM depends mostly on cam, carb, and headwork. Stock motors probably will run faster lowering the shift point in each gear. On juice I have started shifting mine at 6100, both shifts. :shock:
PostPosted: Sun Sep 18, 2005 12:36 pm
Ok, thanks!
PostPosted: Tue Sep 20, 2005 9:12 pm
Every engine seems to have a different "sweet spot" for shift points, on the current stock 225 1 bbl with a small shot of spray, shifting at 4600 RPMs gets the fastest ET :shock: :roll:
PostPosted: Tue Oct 18, 2005 2:40 pm
my motor almost fell flat on its face if i ran it up to 4500, and dam she was screaming at me :shock: so i was shifting at about 3800 was pretty good but my motor is bone stock and normally didnt run to well :? :(
Cuda Progress :D
The dart as it sits now :(
PostPosted: Tue Oct 18, 2005 7:00 pm
I shift at 42-4300rpm it just falls flat after that. I'm not sure why though. I have ported the head, headers, 4 barrel, mild cam and electroninc ignition. I thought it would rev harder after all those mods.
PostPosted: Tue Oct 18, 2005 8:05 pm
4.125" stroke. :idea:
D/W
If it ain't broke, fix it!
PostPosted: Tue Oct 18, 2005 9:08 pm
Phil,
I would suspect either cam timing too far retarded (degreed?) or ignition timing too far advanced. With those mods, you ought to at least get 4500-5000 outta it.
My 68 Dart with MP 0.436" cam, bone stock head, and 8:1 comp revs hard to 4600, and will pull OK to 5000. Timing, induction, and exhaust are pretty tuned up.
PostPosted: Wed Oct 19, 2005 7:11 am
Wow! is this thread still around :shock:
Oh well, keep it going.
PostPosted: Wed Oct 19, 2005 2:32 pm
Actually, an advanced cam will make your top end go away.......
PostPosted: Wed Oct 19, 2005 4:00 pm
it will pull hard to 4300 and will rev higher but it looses power quickly after 4300 I did wind out first gear to almost 5000 once and it made a REALLY loud pinging sound. It will just stop accelerating in 3rd gear at 4500 rpm(105mph with the 3.23's, 90mph with the 3.91's). I was expecting it to rev higher with the 465 holley over the BBD but no dice.
I really need to get some timing tape and see what my total advance is. my inital is 11* and will still ping occasionally using 93 octane(compression is around 9.8:1).
PostPosted: Wed Oct 19, 2005 4:03 pm
...that sounds like a lot of timing for a /6. What's your total mechanical timing? I bet that's your issue.
D/W
EDIT: Duh, I need to learn to read your whole post before I respond! :lol: Yeah, get the tape or a dial-back light, OR, just use your tab scale as a guide to mark off 5 deg. increments on your damper. Crude, but it'll give you an idea without any real effort...
PostPosted: Wed Oct 19, 2005 4:06 pm
SL6 Racer
I shift my race engine at 6200 RPM big cam big valves and injection....I have tried higher RPM but the car does not run any faster.
Dave M
PostPosted: Wed Oct 19, 2005 7:01 pm
Yep, I bet it's ignition advance. Most early dizzys I've seen would give almost 40 deg total mech with 11 deg initial - WAYYY too much. You want 27-30 deg total mech with that comp and setup. You could pick up as much as a whole second in the 1/4 just by recurving your dist and moving total mech down to about 28 deg. Been there...
Ed, you are completely correct. I misspoke - an advanced cam would limit upper RPM power. My mistake.
Dave, what's up with your bad self! Things are good in NC and I'm looking forward to some road racing in a coupla weeks.
 Post subject: timing
PostPosted: Wed Oct 19, 2005 7:42 pm
what inital timing are you working with?
