It is currently Mon Nov 16, 2026 2:46 pm
 Post subject: plastic pieces in engine
PostPosted: Thu Oct 20, 2005 12:38 am
i installed my harmonic balancer on my slant this weekend by tapping it on with a plastic hammer and a pice of wood. when i looked in the oil pan there where several tiny pieces of plastic that where not there before the install. i asuume i banged them loose from somwhere. any ideas?
PostPosted: Thu Oct 20, 2005 3:13 am
Car Model: '23 T-bucket
Take a careful look at your distributor drive gear. Also, did/do you have the cam timing sprocket that has the plastic teeth?
Roger
PostPosted: Thu Oct 20, 2005 4:39 am
Nylon teeth from the cam sprocket?
PostPosted: Thu Oct 20, 2005 10:07 am
the distributor was not in the motor at the time. is the cam timing sprocket hard to replace?
PostPosted: Thu Oct 20, 2005 2:27 pm
Well, you start by pulling the balancer off you just put on..... :shock:
Users browsing this forum: Google [Bot] and 11 guests
