It is currently Tue May 05, 2026 4:57 am
 Post subject: Steering pin removal
PostPosted: Thu Oct 20, 2005 8:02 am
I have finally given up on my '74 Scamp power steering box and I plan to remove it this weekend. Is the coupling pin tappered? I tried to reove it once before and could not bugde it so I gave up. Now I'm determined. Any hints on getting it out would be appreciated.
Thanks.
Sweet Emotion
PostPosted: Thu Oct 20, 2005 9:56 am
After three decades in place, those pins can really be stubborn. It's not tapered; it's just a standard split roll pin that can be driven out with a properly-sized punch and a BFHammer. Applying Kroil or Coca-Cola can help.
PostPosted: Fri Oct 21, 2005 8:35 am
For stuck, rusty parts, I have found PB Blaster to be best thing on the planet. Soak it in it for a while and it should make things go much smoother.
PostPosted: Fri Oct 21, 2005 3:03 pm
Well I got 'er done. Soaked it with WD40 overnight and she came right out. Got the whole gear reamoved and replaced in less than 3 hours. And flushed and all new fluid. Works great so far. I was having some very strange power steering problems but they seem to be gone.
Thanks all.
Sweet Emotion
PostPosted: Fri Oct 21, 2005 3:53 pm
Probably 'cause ya never tried Kroil :-)
PostPosted: Fri Oct 21, 2005 3:57 pm
And I thought you're supposed to use TransX..............
:twisted:
PostPosted: Fri Oct 21, 2005 4:30 pm
Where does one find this magical kroil stuff in the US?
PostPosted: Fri Oct 21, 2005 5:22 pm
As far as I know, Kroil is only available direct from the manufacturer.
Kano Laboratories
1000 S. Thompson LN.
Nashville, TN 37211
1-800-311-3374
PostPosted: Fri Oct 21, 2005 6:39 pm
The Eastwood Company sells it mail order or on their website.
http://www.eastwoodco.com/
just search for Kroil - they have an aerosol and a larger size (half gallon?)
PostPosted: Sat Oct 22, 2005 6:34 am
Much cheaper, here.
https://secure.cnchost.com/kanolabs.com ... rial.shtml
PostPosted: Mon Oct 24, 2005 12:12 pm
We have used Kroil and PB Blaster here at work. They are both exceptional products. :shock:
