It is currently Mon Nov 16, 2026 1:44 pm
 Post subject: '79 engine in a '64
PostPosted: Fri Oct 21, 2005 5:49 pm
Contributor
To make things go a bit faster when it's time to pull the engine from my '64 Valiant convertible, I'm going to build up a '79 engine and have it ready so I can swap over a weekend.
I know the cranks are different and that I will need an adapter spacer for the converter nose, but is there something else I might be forgetting?
This is for a car that is never raced, so the rod size and cast crank are not a concern.
Does anyone know a source for the converter adapter?...or will I have to visit a machine shop to get one made?
 Post subject: Torque Flite Pattys
PostPosted: Fri Oct 21, 2005 6:27 pm
Pat Blais sells the adapters from his Ebay store.
http://stores.ebay.com/TFlite-Pattys-Sh ... idZ2QQtZkm
oil pan and pick up will be an issue - The 79 pan does not
fit with the /6 center link and the 62-66 kmember.
PostPosted: Sat Oct 22, 2005 4:48 am
Contributor
Thanks for the link!
Yes, I knew I will have to swap pans and pickup, but thanks for reminding me.
PostPosted: Sat Oct 22, 2005 5:21 am
You will also need the flexplate/flywheel from the later engine.
