It is currently Thu May 14, 2026 10:17 am
 Post subject: New Rearend
PostPosted: Mon Oct 24, 2005 8:35 pm
Alright guys, im not sure if this place is like the HAMB and i ahve to do a intro, so ill jsut do a quick one, and get to the point of this post. Im a 18 year old kid whos working on a 1966 Valiant v100. I know i have to upgrade the brake system, and im researching that in the Brakes section right now, but allmy car friends tell me i have to put a new rearend in it. Is this a necessity? if so, why? and if it is, what kind should i use? Thanks for your time, Evan
PostPosted: Mon Oct 24, 2005 8:39 pm
guh...that was me, yeah, im a new guy, what can i say...
if its yours, nobody has to like it except you...
PostPosted: Mon Oct 24, 2005 9:08 pm
H'mm. There are possible reasons why you might want to install a different type of rear axle, but not so much to get better brakes (there are plenty of good brakes that fit a stock '66 Valiant rear axle) but to get a stronger rear axle assembly.
What kind of driving are you doing, and what is leading you to want to upgrade the brakes? Better brakes are always nice, but standard brakes work fine if they're in proper repair.
Also remember, if you only have time or money to upgrade half the brake system at a time, always start with the front. Better brakes only in front = better stopping. Better brakes only in rear = lockup, spin, crash.
PostPosted: Mon Oct 24, 2005 9:14 pm
oh i definatly am upgrading the front first, up to disc brakes, i shoulda been more clear...and, well, lets just say im driving like a 18 year old, haha...so, do i need a better rearend? and if so, why, what kind, you know that sort of thing...thanks again guys
PostPosted: Tue Oct 25, 2005 5:57 pm
Better brakes are a good idea. Which kind are you going to install? Be careful in selection and installation - lots of people depend on it.
One reason for changing rears is to get the 5 on 4.5" bolt pattern to match the pattern on the 73-76 A-body front disk brakes a lot of people use. A better variety of rims is available in that size than in the 5 on 4", and having the same bolt pattern all around is a good thing in my book.
 Post subject: rear end
PostPosted: Wed Oct 26, 2005 1:21 pm
what are you ultimate plans with the car? big horsepower, lotsa torque? if thats what your going for then yes you need to upgrade to a stronger axle. better brakes usually come with it. whether you get a ford 8", mopar 8.25" or 8.75", all those axles come with a larger 5x4.5" bolt pattern vs. the 5x4" bolt that will be in the front. now you have to carry two spares or chenge the front end to the larger bolt with either the 73-76 A-body discs or the 76-80 aspen/volare discs. you need to sit down and plan your build up of the car so you know which direction you need to go. keep coming back and we'll help.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Wed Oct 26, 2005 11:07 pm
Don't forget Ford 8.8
PostPosted: Fri Oct 28, 2005 9:16 am
i just want to make a cruizer. gunna keep the 170, origional everything, pretty much. Its gunna be lowered, front brakes upgraded (whats the best kind to use?) and i donno about the rear end yet...the two spares is a good point. Thanks for your time guys
 Post subject: gunna keep the 170
PostPosted: Thu Nov 03, 2005 12:10 am
If you arent going to change to a V8 I wouldnt change the rearend at all. There is no point. You are young and I would guess this needs to be cheap. Just make sure the rear brakes are right, upgrade the front brakes to disc and be done with it. Im sure you want to put most of your money in the looks and interior. At least I did when I was a kid. :P
James E. Faith
My First Ride built 14 years ago....still got it!
http://www.pctradepost.net/images/71.jpg
PostPosted: Thu Nov 03, 2005 7:09 pm
i like what im hearing from you, haha...im actualy looking to keep the origional interior and just rattle can the car primer black, until after college (4 years) when i chop the top and shave the handles, then im going with a cream interior, and gloss black, with red metal flake roof and scallops...i was talking to a buddy of mine, he told me to just get a universal spare, so i thin kill go with that, and keep the rear end. But he also mentioned how he thinks a rear and brake parts from a Volari (sp?) wagon would work well with the 66'...any thoughts?
