It is currently Tue Nov 17, 2026 8:31 am
PostPosted: Tue Oct 25, 2005 5:14 pm
Hey guys
check this out:
Stock piece to start from scratch
I drill concentrical holes starting with a 5/16 drillbit...
removing the center piece
till I reach 1/2" with a drillbit. I keep on enlargening the inner diameter to 0.55" but using a lathe tool (see pic below)
then...
I use solid aluminium stock (not delrin, DW... :lol:) to line the centerpiece
I mark the piece so the passages match
And finally I have the centerpieces ready to install (I haven't worked on the inner wingfoil profile at this point)
This is the thinwall, not so restrictive annularm boosters that I have come up with
Now, I haven't installed them yet but I can't wait to evaluate the results.
Inputs? please, don't panic (or, panic: don't)
Juan Ignacio Caino
PostPosted: Tue Oct 25, 2005 5:35 pm
that looks fab!!
curious to hear how it performed!!!!
 Post subject: Looks Good........
PostPosted: Tue Oct 25, 2005 7:03 pm
I'd clean up the casting mark on the outside of the orginal too.........
Any way to airfoil shape the round leg??????
Teardrop shape should do it. Or make an aluminum tail for it.......... :wink:
 Post subject: Re: Looks Good........
PostPosted: Tue Oct 25, 2005 8:32 pm
That's next along with keeping the cutting edge and the trailing edge as thin as humanly possible
Nice! we think alike! I'm looking over epoxying some ^ shaped piece of aluminium (or delrin, my fetish material) along with giving the exterior leg a good filing on the sides to obtain this () shape instead of the regular O
yes. I'm going slow cuz I wanna document all the process so if anyone wants to follow this mad fabrication is clear and graphic. I can go on talking tons of theoretical stuff but one image is worth thousands of words... :wink:
BTW forgive all my mistyping lately, I'm going like hawkins? no. I just changed my KB and I didn´t got one replacement for my "latinamerican" distribution, I'm fighting with this "Spanish-Traditional" unit. Shoot!.
Juan Ignacio Caino
PostPosted: Tue Oct 25, 2005 8:33 pm
Hey ed, that's like passg seat fabrication, not "backseat anymore :lol:
Juan Ignacio Caino
 Post subject: Hobby stores..........
PostPosted: Tue Oct 25, 2005 9:51 pm
Check out some hobby stores..........
there's tubing that's in the shape of airfoils....
PostPosted: Tue Oct 25, 2005 10:17 pm
there's a good company up there called K&S or K&D engineering from chicago that produces a mouthwtering variety of diffrent tubing, solid stock and shaped pieces of metal (good quality brass, top otch aluminium) for modeling purposes....
Juan Ignacio Caino
PostPosted: Tue Oct 25, 2005 10:54 pm
It's K&S
PostPosted: Wed Oct 26, 2005 9:06 am
PostPosted: Wed Oct 26, 2005 9:07 am
It's K&S
Got a link?
PostPosted: Wed Oct 26, 2005 11:23 am
http://www.ksmetals.com/
But I've found better descriptions elsewhere?????????? (which I can't find at the moment :cry: ) (K & S tubing, K & S streamline, towerhobbies,..... might work)
PostPosted: Wed Oct 26, 2005 5:09 pm
Car Model: 1964 Valiant 2dr post
Sorry I haven't been posting...been working way to much and am flying out to CA this weekend, then home to Portland for a few days to solve a major issue there...
However, I need to say something about this project...
You want the outside of the booster to remain straight because you need to create an airfoil that generates lift...or (low pressure) at the top of the hump.
A teardrop shape is known as a symetrical airfoil and does not generate "lift". You will end up with less signal. You will still develop low pressure because the air still has to accelerate accross the wing to meet up on the other side, which will produce a signal at the correct location. On an airplane wing, however, the net is lift on both sides, so that the "lift" is nuetral and produces only stability...this type airfoil is commonly used on model aircraft design for aerobatics, so that the plane behaves similar upright or upside down.
So on your booster, it will produce a stronger signal on the discharge side relative to atmospheric in the float bowl if you stick with a flat bottomed airfoil(outer edge) and maybe only experiment with leading edge transition and airfoil shape.
Although they make tubing, It is designed to be used as skirts and such for landing gear, and probably not much help in your project.
I would use a dremel or die grinder with one of those long tapered sanding rolls and sand your way in from the bottom. On top, use progressively smaller ball stones to initiate the shape, then switch to a small sanding roll that you where out ahead of time on something hard so that it helps form the shape.
When close, switch to Dremel with polishing wheels and course compound to polish and finalize the shape.
This is how I modify and enlarge the boosters on Qjets. Time consuming but good results.
Must go, my business partner just flew into Charlotte and I must go meet up with him...
Later
Gearhead
64 GTO...10.80's@122 on street radials
Destroked 455, Qjet, stock ign, 2400 stall
64 Valiant
Old 225, 4spd, 2.92-8.75, 2bbl, headers
dual 2.25"
PostPosted: Wed Oct 26, 2005 6:31 pm
The teardrop/airfoil shape wasn't for the booster part, it's for the leg that supports the booster... Getting rid of a round leg and streamlining should help your flow.............
BTW, the original booster looks quite restrictive with that large tube in the middle................
PostPosted: Wed Oct 26, 2005 6:51 pm
Hey Karl and guys
Karl, as Ed stated, the teardrop or double airfoil is for the leg. As far as for inner shaping I did it by hand, on the lathe, with diffrent kids of burring knifes. I don't know if you're familiar with NOGA, a brand from Israel, they make some serious deburring tools for fine mechanics and machinists.
I got some pix while doing it but came up blurry because I was shaping on a revolving chuck with one hand and trying to aim a big FD mavica on the other..... not the best way of getting it done. I'll take some closeups of the inner shape and post it soon. After doing all the shape I mirror polished all the inner airfoil spahe, and I'm deburring the casting marks soon and mirror buffing them on the outside too.
I guess that I'll need leaner jetting, huh?
Juan Ignacio Caino
PostPosted: Wed Oct 26, 2005 7:09 pm
I actually have no idea what you'll have to do with the jetting..........
If there's better airflow (less obstruction), you might get more air and need to go richer............
It's trial and error time.............. :twisted:
