It is currently Fri Nov 20, 2026 3:18 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
 Post subject: Headers and a Turbo?
PostPosted: Fri Oct 28, 2005 2:10 pm
This may be a dumb question, but one worth asking just for the information. How would steel tube headers work out with a small turbo, like a t03? I know cast iron would be better, but for a low boost situation, would the header hold up? Is there much of a chance of it having a critical meltdown? I swear I've seen this done on other types of cars, I wonder what material they were using for the header.
the most expensive free car I ever got - 74 special edition
PostPosted: Fri Oct 28, 2005 2:21 pm
From what I've heard they would work OK for low boost and/or not on boost all the time (like drag racing).
PostPosted: Fri Oct 28, 2005 2:46 pm
In high heat applications (i.e. turbo or rotary engine) you want either stainless steel tubing or a thick-walled steel tubing (normal header tubing will start to deform with the heat)
PostPosted: Fri Oct 28, 2005 2:56 pm
The name of the game with a turbo is heat retention. Every bit of heat the exhaust loses on its way from the engine to the turbo means energy that's not available to spin the turbo. Cast iron manifolds are good at retaining heat. Tubular headers are lousy at retaining heat. There are heat-retaining technologies—wraps and coatings—that can be applied to tubular headers to help keep the heat in, but be aware these cause the tube itself to run much hotter, greatly shortening its life before it fatigues and fails. So...pays money, takes chances, etc!
PostPosted: Fri Oct 28, 2005 3:52 pm
The strength of mild steel is much less when it's glowing red hot. Even stock naturally aspirated engines can heat headers cherry red. On a turbo application, a header that was quite adequate for supporting the weight of the turbo at room temperature may not be strong enough at full power. I've heard that turbo headers made of thinwall tubing seldom last longer than a couple thousand miles on the street. Supporting the turbo's weight primarily with a mounting bracket of some sort can help this, but you are much better off welding the headers from thick-walled tubing, say 12 gauge or thicker. Even then I might want some extra bracket holding up the turbo.
Many tube headers for turbo applications are actually made from heavy duty hydraulic tubing.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Oct 28, 2005 4:09 pm
Yeah, I was thinking about the bracket thing. Wouldn't that be a good idea in a cast iron manifold situation anyway though? With a support bracket in plact it would take some of the stress off the manifold to let it move as it heats up and maybe keep a better seal, instead of pulling the whole thing down and pulling at the seal on top.
How would you go about getting/bending hydraulic or regular 12 ga steel like that?
PostPosted: Fri Oct 28, 2005 7:18 pm
SSRN National Champion
Ask Tom Drake that question Thanks Ron Parker :D
Hey Has That Thing Got A Bagel Bamboozler In It
PostPosted: Sat Oct 29, 2005 4:34 am
There is always the weld els...
PostPosted: Sat Oct 29, 2005 6:18 pm
What the hell is a weld els Thanks Ron Parker :D
PostPosted: Sat Oct 29, 2005 7:26 pm
I was wondering the same thing, I can't seem to find one anywhere on ebay.
PostPosted: Sat Oct 29, 2005 7:42 pm
Thick cast(?) steel pipe, and bends.
I can get them at steel suppliers, or any plumber...
very nice and easy to work with, but heavy...
I think they are used for steam, and maybe water? and different kinds of gas
My old school used them to feed torches, and welding thingies, and compressed air...
PostPosted: Sat Oct 29, 2005 8:12 pm
Well bless your soul we keep learning everyday Thanks Ron Parker :D :D
PostPosted: Sun Oct 30, 2005 12:51 am
Not too pretty, but maybe you see what I mean?
PostPosted: Sun Oct 30, 2005 9:49 am
Very cool pictures! Would that kind of setup have to be 'hot' welded like the stock manifold. Where you heat the parts being welded up, weld them, and then cool them at a controlled rate? I read that will make everthing stronger? I really am excited about BBQing my manifold on the gas grill, I just don't know if it will turn out all right.
PostPosted: Sun Oct 30, 2005 12:03 pm
Not really, it is ordinary steel, but go ahead, I don´t think it will hurt anything :P
My local plumber is a car freak, and he can get most any kind of piping, and bends, in stainless, steel, or titanium, in most dimentions, and degrees(on the bends)
And he can get donuts too, and they could be nice for some things(but I still wonder how they make them :? )
In some sizes he can even get inconel, but it gets really expensive, really quick :wink:
I think the normal steel will be strong enough for just about anything, with the thick walls, but stainless would be sweet 8)
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
