It is currently Wed Nov 18, 2026 4:02 am
PostPosted: Sat Oct 29, 2005 3:08 pm
How much can you actually overbore a 225 Slant Six? The Mopar Six Cylinder Manual says 0.060 for 1960 - 1973 and 0.030 for 1974 - 1984.
Are these really conservative or absolute numbers? Are the numbers above only relavent to racing engines or any Slant Six?
PostPosted: Sat Oct 29, 2005 3:19 pm
The iron-block slant-6s tend to be very meaty and many of them can support a large overbore—"large" being 0.090" or even 0.100"—but if you're thinking of going beyond 0.040", it's critical on any engine to sonic-check the bore wall thickness, because at large overbores, if you happen to have a block with more than average core shift, you can weaken or break through the walls.
If you smoke, the Mopar Performance 6-cylinder engine manual makes a convenient stack of pieces of paper you can tear out, one at a time, and use to roll and then light cigarettes. If you don't smoke, it makes a nifty coffee mug rest or doorstop. The book contains an uncomfortably large number of factual errors, and even more statements that might not be out-and-out wrong, but are certainly overextended. These categorical overbore limits for all engines are a great example of the latter type.
PostPosted: Sat Oct 29, 2005 3:38 pm
SSRN National Champion
Dan is right again 40 thousand or possable 60 thousand. I bored my race engine out 100 thousand and hit a sand cast hole and had to sleave one cylinder. Also with that much bore we hard blocked the water jackets to prevent distortion Something we were going to do any way but you could not do that on a street engine. Thanks Ron Parker :D
Hey Has That Thing Got A Bagel Bamboozler In It
PostPosted: Sat Oct 29, 2005 4:36 pm
My shop manual for my 1980 D-150 says maximum overbore is 0.040.
Is this to be heeded or is this more cigarette paper material?
PostPosted: Sat Oct 29, 2005 4:46 pm
I'd probably be pretty cautious about overbore on the '80-up engines, but the takeaway point here is that there's no number in a book that can tell you what any particular engine will tolerate. A lot of times the service manual "maximum overbore" dimensions are governed not by the limits of the block, but by the service replacement pistons available from the manufacturer at the time the book was printed!
PostPosted: Sat Oct 29, 2005 4:55 pm
So, if I overbore my '80 225 to 0.040 am I alright or should I expect problems? And if I have problems how will they show up?
PostPosted: Sat Oct 29, 2005 5:16 pm
I can't imagine you'd have a problem at 0.040" on an '80 engine, but what's the purpose of the overbore? Clean up damaged cylinders? Extract more performance?
You will be fine with .40 over.
If the boring bar falls through the block its easy to find another.
I just bored my street block 40 over and it never even noticed. (It did like the nice bath they gave it before and after)
This may sound silly,,,,but a good visual inspection of the block is always in order before sending it to the shop,,,,look for holes and cracks etc...cuz it costs just as much money to tank a bad block as a good one.
PostPosted: Sat Oct 29, 2005 7:43 pm
what about that suggestion that reverting the piston assy (meaning, assembling it with the notch that indicates "forward" pointing backwards, you can reduce engine's friction and wear? BS too? I assembled my engine that way.... should I be concerned.... :cry:
Juan Ignacio Caino
PostPosted: Sat Oct 29, 2005 8:05 pm
Done a 340 that way 9 years ago on a cruse in 65 Baracuda no problems. Some say you might git a little piston slap noise but with a 284 cam and flowmasters i aint ever heard any slap just burning rubber.
Thanks Ron Parker :D :D
PostPosted: Sat Oct 29, 2005 9:45 pm
Most any Slant block will go +.100", and some of the race car guys are going +.135". :shock:
PostPosted: Sun Oct 30, 2005 6:58 am
The machinist said he had to go to 0.040 to clean up one of the cylinders. The motor had 222,000 miles on it. I guess the extra displacement isn't all bad. :D I am hoping for some nice performance in a relatively heavy vehicle. You guys have really helped me put this together. This is my first attempt at anything like this and it is a hoot working on the Slant!
bwhitejr
PostPosted: Sun Oct 30, 2005 8:44 am
yeah i agree everyone one on here is very helpfull, on other message boards for my honda :shock: :evil: everyone is a street racing punk who flames you all the time. :x ive posted up some questions but nobody will awser them :shock: in the racing q and a and engine :shock:
Cuda Progress :D
The dart as it sits now :(
PostPosted: Tue Nov 01, 2005 11:21 am
My '87 block in my '87 D150 is .080" over.
No problems to date.
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Wed Nov 02, 2005 2:45 pm
wow 80 over dang thats alot id like to do my block .60 over i dont really know where to find pistons :( i found molly rings on summit but no pistons :evil:
Cuda Progress :D
Users browsing this forum: Google [Bot] and 9 guests
