It is currently Sat May 09, 2026 1:58 am
 Post subject: universal
PostPosted: Sat Nov 05, 2005 6:28 pm
how do i check the fluid in my universal joint?
i have a 225 7 1/4 rear end.
also, if i need to re fill it, what is the procedure, can you recommend a lubricant?
God took you away, then brought you back to me.
PostPosted: Sat Nov 05, 2005 6:34 pm
The fluid level in the rear end, when you remove the drain plug (when facing the rear from back of car, on the right side of the cover, on a 7 1/4 rear) should be just to the bottom of the plug when car is on a level surface.
Standard 80w90 weight gear oil should be fine.
