It is currently Sat May 09, 2026 3:48 am
PostPosted: Mon Nov 07, 2005 8:26 am
Hello folks,
In reading old posts and such I don't see this answer, but see a lot of sniffing around it. In my '64 d100 truck, I use P235 15 inch radial tires and a 3.91 rear end. What number of teeth should be on the speedo drive gear in an A833OD transmission mated to this tire/rear end combo? I don't see a way to calculate it.
I just installed one with 37 teeth that was sold to me as the "right" one, but see on ebay someone says a 40-tooth gear is correct, and I have one with 29 teeth I just pulled from a tranny that came from an 84 dodge truck.
Anyone know for sure, or how to calculate it?
thanks
rock
'64d100
PostPosted: Mon Nov 07, 2005 10:22 am
Not enough info. "P235 15" is not a tire size. We need to know the actual tire size, including the aspect ratio.
Tire sizes look like this: "P235/75R15" or "P235/60R15" or "P235/70R15" or...
PostPosted: Mon Nov 07, 2005 12:59 pm
Try this:
http://www.moparts.com/Tech/tech/pages/speedo.html
Get the excel worksheets at the top of the page and you can just type your tire size and rear-end ratio into the correct fields and it'll spit out the correct number of pinion teeth (you'll have to round to the nearest available)
PS- you didn't give a complete tire size in your post.
PostPosted: Tue Nov 08, 2005 6:40 am
FOlks,
My apologies re. omitting part of the tire size ...just a plain a-- error. But thanks for effort reading and replying and that XL sheet is killer, I sure have it in my favorites now! Man, what an info source this forum is!
rock
'64d100
 Post subject: speedo cable/gear
PostPosted: Tue Nov 08, 2005 4:29 pm
Car Model: 1974 W100; 72 Dart
my 65 needs a speedo cable or at least the gear that goes into the tranny. it is the original 65 tranny. anyone know where to get that?
sb
