It is currently Fri Nov 20, 2026 1:32 pm
 Post subject: Dutra Duals
PostPosted: Tue Nov 08, 2005 6:18 pm
I just got my front casting of dutra duals from doug and I was wondering what was the easiest way to drill the holes for the studs to mount to the cylinder head. I've spent my wad on this car and I sure don't want to mess these up.
PostPosted: Tue Nov 08, 2005 10:29 pm
I made the same mistake when I recieved my Dutra's. You do not need to drill any holes to mount the manifold. They are made that way so they can be used as the rear manifold when you use them as a pair.
 Post subject: Dutra's
PostPosted: Wed Nov 09, 2005 6:08 pm
Maybe I'm not understanding, but if I don't drill any holes how do I mount the manifold? What will hold the casting to the cylinder head?
PostPosted: Wed Nov 09, 2005 8:26 pm
The triangle washers on the studs from the head hold the "tips" of
the manifold - similar to the middle mounting areas of the stock
exhaust manifold. Half of the washer holds the intake manifold and
the other half of the washer holds the exhaust manifold (whether it
is a stocker or a Dutra)
 Post subject: Old Mock up pic.
PostPosted: Wed Nov 09, 2005 10:06 pm
Should look a little like this...
good luck,
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
