It is currently Fri Nov 20, 2026 2:39 pm
 Post subject: Motor Mount Replacement
PostPosted: Wed Nov 09, 2005 10:40 am
Lost a motor mount on the way home from work last night (and I mean LOST — the alternator is resting against the passenger inner fender!). Replacement seems pretty straighforward, but the only time I've done it was on a V8 when the engine was out of the car. Any tips or tricks that would ease/quicken the process? I don't have a cherry-picker — can I do this job with a floor jack? As usual, thanks a bunch for your insight!
VM
PostPosted: Wed Nov 09, 2005 10:58 am
On a slant if it is the drivers mount simple with a floor jack and a block of wood. Pass side can be a little tight fitting but doable. It really comes down to what kinda car it is in.
PostPosted: Thu Nov 10, 2005 5:35 am
Sorry, I should know better by now. '72 Swinger, automatic. I'll be replacing both while I'm at it, but it's definitely the passenger side that failed.
VM
Users browsing this forum: Ahrefs [Bot], Bing [Bot], DuckDuckGo [Bot] and 4 guests
