It is currently Fri Nov 13, 2026 7:57 pm
PostPosted: Wed Nov 09, 2005 2:51 pm
I have a 1964 Dart with push button shift 904 trans. Trans (rear pump) is bad. I have a "donor" car 1965 Plymouth Valiant with a one year old rebuilt trans. The Valiant is a column shift. Any problems getting the push button cable shift mated to the column shift trans ? Thanks !
PostPosted: Wed Nov 09, 2005 3:12 pm
Yep, you can use a '65 trans with minor modifications. See threads Here and Here.
PostPosted: Wed Nov 09, 2005 4:42 pm
Just install the valve body from the 64 PB trans in the 65 column shift trans. I would also swap out the speedo gear on the end of the cable, in case they are different ratios.
PostPosted: Wed Nov 09, 2005 4:50 pm
Related info if you can't rebuild your cable-shift transmission, or find a replacement: Imperial Services can make pushbutton and '65 console or column shifters work with '66-up 904 transmissions.
http://www.imperialservices.net/Imperia ... 0Parts.htm
Scroll about halfway down.
I'd prefer to keep my cable shift transmission, but it's nice to have an option.
PostPosted: Wed Nov 09, 2005 5:33 pm
I have both console and column shift adapter kits from Imperial Services and both are first class all the way.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Wed Nov 09, 2005 5:35 pm
I've heard good things about Imperial Services' stuff.
However, in three years of intermittent attempts, they have never returned an e-mail I've sent them, and I've never been able to get them on the phone. Eventually I just gave up. Have they got their shìt together now?
Users browsing this forum: Amazon [Bot] and 4 guests
