It is currently Fri Nov 20, 2026 8:05 pm
 Post subject: Motor mount dimensions
PostPosted: Thu Nov 10, 2005 7:17 am
Contributor
The new motor mounts for my '64 Valiant are from two different manufacturers and though the part numbers are correct, the driver's side mount is 1/4" thinner than the passenger side. My old mounts are so bad, there is no way to measure them to see if they were the same.
Does anyone know if this is the way they were designed?...or do I need to think about a spacer plate?
