It is currently Sat Nov 21, 2026 6:48 pm
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Fri Nov 11, 2005 4:17 pm
it's definitely still buoyant, but thanks for the thought. Im running short on them right now.
So were the Quadrajets............. The float just absorbed enough fuel that with fuel pressure behind the needle valve you'd flood out....
I only figured it out by weighing the float, letting it sit overnight in gas, and weighing the float again............
If you've got extra floats, might as well give'em a try
PostPosted: Sat Nov 12, 2005 6:25 am
on e-bay now.
http://cgi.ebay.com/ebaymotors/N-O-S-Mo ... dZViewItem
PostPosted: Sat Nov 12, 2005 7:00 am
I dont think the fuel level in the bowl is all that high, though... if anything, it's a tad low. The level when I stalled out was about 3/4" to 7/8" from the bottom when I checked it yesterday.
PostPosted: Sat Nov 12, 2005 8:42 am
on e-bay now
Be careful if you buy this pump ("you" means "anyone"). The P/N indicates this is indeed a '60-'62 pump. There was a TSB on those, because some of them were built with unhardened pump arm pivot pins, which promptly wore through and caused the pump to stop pumping. The same M2996s pump was given a new Chrysler P/N (which I don't have handy, think it was 2279xxx) and the field test for whether your pump had a hardened pin or not was to attempt scratching the pin with a file.
In any event if I came across a NOS pump like this and wanted to use it, I'd first put in a rebuild kit, to get rubber materials proof against modern gasoline. The kit comes with a new pivot pin, so that problem wouldn't exist any longer.
PostPosted: Sat Nov 12, 2005 9:13 am
on e-bay now
Good info, Dan. I was not aware of that.
PostPosted: Sat Nov 12, 2005 11:45 am
New info:
I went to the studio and found a metering block from an old cracked carb I found at a scrapyard (forgot I even had it) and immediately rushed home and threw it on. Here's something interesting, whatever fuel was left inside the metering block spread a bunch of silvery dust all over the accelerator pump diaphragm and gasket, it could be filings from the hold-down screws or maybe it was blasting sand, who knows. I also found a spare float retainer clip under the diaphragm!
Anyway, I tested the carb today and it wont idle. It seems to be flooding as it needs less throttle pressure to run when I have the mixture screw bottomed. I reset the float back to spec and tried again, same thing. Throat is wet with fuel. I am currently running a #64 jet.
Does the idle circuit go through the metering block at all? If I went down to a #60 jet would that help? (I know the main and idle circuits are not one in the same, but I have plenty of different jets to work with) Better yet, does anyone have any flow diagrams for this carb so I can get a better understanding of this metering block and what it does? I would like to get this car idling again so I can take it for a rip and see what that does to my stumbling problem.
 Post subject: success
PostPosted: Sat Nov 12, 2005 3:27 pm
Well, the car runs as normal, and I think this is why:
I futzed with the spare metering block for awhile today without success. I then decided to shoot some brake cleaner through the original metering block and put it back on. Test drove it with a #62 jet, the problem did not return. I bagged it on the 403 for a good 20 minutes and no stumbling. I did notice the temp was high, probably because Ive been running lean with this carb all this time and went down a few sizes. So I got home and changed to a #66, drove it again and it ran beautifully. My best guess is that spare E-clip was dancing around in the pump well and blocked a passage. Maybe it was wedged between the diaphragm and the backup plate and finally dropped down, who knows.
Thanks very much to all who responded, it has been a very interesting and expensive couple of days, I hope there are some takeaway lessons we all can glean from this experience. I have to say Dan hit the mark, it was the carb all along and still is. That matter will be resolved soon.
PostPosted: Sat Nov 12, 2005 4:36 pm
Glad you got it working :)
I'd think that a piece floating around would cause random symptoms...... sometimes it works, sometimes it doesn't; rather than the rather consistent problem you had with problems seeming to occur within a consistent time frame :?: :?: :?:
PostPosted: Sat Nov 12, 2005 4:50 pm
yeah, who knows. Id like to learn a bit more about that metering block, right now it's just a mystery labyrinth of passages and needles and airbleeds that make no sense. It bugs me.
Users browsing this forum: Amazon [Bot] and 4 guests
