It is currently Sun Nov 22, 2026 5:21 pm
 Post subject: Cams
PostPosted: Fri Nov 18, 2005 8:41 am
Just a note to the ignorant, as I was until recently. In thinking about a cam for my 225, I imediately thought of Comp cams because of their advertising.
Somewhere in the course of my reading, I found that RACER BROWN Cams have Mopar, Nisan, and BMW FACTORY PART NUMBERS.
I'd sugest checking them out. Has anyone had experience with their cams ?
Irv83
'62 Lancer Gt ..225 Auto, Offy /Demon/MSD/clifford/DB
 Post subject: racer brown cam
PostPosted: Sun Nov 20, 2005 12:56 am
personal experance was on a 426 max wedge I build using a Racer brown cam. no cam problems.
Wild 1 AKA William Robertson
Owner Builder
65 Dart 270 2 door post /6 stock
89 dodge diplomat
66 Plymouth Barracuda
70 Challenger 451 ( Sold )
95 Chy New Yorker ( Stock )
PostPosted: Sun Nov 20, 2005 4:04 am
Years ago Mopar's Direct Connection catalog always used to include a couple of Racer Brown camshafts in the Slant Six performance section.
I probably could locate one of my old catalogs to find the specs, if you'd like.
-Mac
PostPosted: Sun Nov 20, 2005 5:24 am
I had an old Racer Brown in my first good Slant. It was a little one, but made excellent low and mid-range power.
Had a Comp Extreme Energy in motor #2. Made good mid-range and top end power.
Had a bigger Clifford in this year. Loved nitrous.
Had a Mopar Performance 528 in the first motor. Made excellent power (was my fastest all motor passes) but ate the oil pump gear and welded the motor. :shock:
PostPosted: Sun Nov 20, 2005 6:26 am
Is that the cam you sold me? I'm still running it in my 66Cuda, err, was til I ate a couple of pistons.
PostPosted: Sun Nov 20, 2005 5:50 pm
SSRN National Champion
Hey yall racers see what has come up on camshafts. See Racing Q@ A and get your motor running. Thanks Possum
Hey Has That Thing Got A Bagel Bamboozler In It
PostPosted: Sun Nov 20, 2005 6:01 pm
Racer Brown is the way to go in a solid lift cam. Great power -no problems.
Will
PostPosted: Sun Nov 20, 2005 7:39 pm
Yep. At one time I had 2 of them. :shock:
