It is currently Thu Nov 12, 2026 4:22 am
PostPosted: Sat Nov 19, 2005 3:07 pm
I have a 318 cu in 77 Volare which needs a spider gear. I have located a 5th Avenue and a Lebaron with 7 1/4 rearends. Will they directly swap out or would it be better to just replace the spider gear only?
PostPosted: Sat Nov 19, 2005 3:16 pm
They will be a direct swap. - The gear ratios might be different than what you currently have, but otherwise than that they bolt right in.
 Post subject: Don't forget...
PostPosted: Sun Nov 20, 2005 5:15 pm
When you swap the rear, grab the speedo gear out of the donor car's tranny (especially if you the rear ratio changes....)
-D.idiot
