It is currently Tue Jun 16, 2026 2:57 pm
 Post subject: Gas Tank Vent Tube
PostPosted: Mon Nov 21, 2005 9:05 am
What size, outside diameter is the filler vent tube for the gas tank in my 63 Valiant. PO decided he didn't want it, but I sure do. Can't seem to locate one locally so I think I will make my own.
PostPosted: Mon Nov 21, 2005 10:03 am
Should be able to bend-up your own out of steel brake line tubing. Pretty sure it's 1/4", but it could be 5/16". Make sure to follow the factory routing (out from the boot in the trunk floor, zagging steeply upwards along the left rear wheelwell, making a fairly tight U-turn and then back down along the wheelwell over to the fitting at the outboard end of the filler pipe).
 Post subject: Vent tube
PostPosted: Mon Nov 21, 2005 10:37 am
Did they design it that way to keep you from pouring gas all over the top of your tank if you screwed up refilling? Thanks for the help.
PostPosted: Mon Nov 21, 2005 10:42 am
Mainly to prevent a siphon effect.
 Post subject: smaller
PostPosted: Mon Nov 21, 2005 8:08 pm
5/16 is the main fuel line size.
On the non-emission setup the vent tube is much smaller than
the main fuel line
BYB - (to the garage with the calipers ....)
The vent line measures 1/4 inch OD
