It is currently Fri May 15, 2026 10:48 am
 Post subject: 13" Tires, 14" or 15"
PostPosted: Mon Nov 21, 2005 12:32 pm
Anyone looking for tires to fit a "stock" rim (13" x 4 1/2")('60 - 62 Valients and Lancers) be advised that Kumho (sp?)
makes a 185/80x13 decent radial for $34+, + shipping per tire at the "Tire Rack" (1-(800)981-3782).
NOW, does anyone know of a year , make, and model Mopar whose 14" or 15" rims will fit a 5 bolt, 4" circle, early Lancer ?
Thanks !
Irv83
'62 Lancer Gt ..225 Auto, Offy /Demon/MSD/clifford/DB
PostPosted: Mon Nov 21, 2005 12:42 pm
You can get 14 x 4-1/2" plain steel rims from a '65 through '76 A-body with the small bolt pattern. You can get 14 x 5-1/2" plain steel rims from a '65 through '72 A-body with the small bolt pattern. You can get 14 x 5-1/2" rallye wheels from '67 through '72 A-body with small bolt pattern. All of these can be searched via www.car-part.com . Any 15" wheel with small bolt circle will be a custom-build job. There are also aftermarket choices, such as the Cragar S/S units I have on my '62 (which, more and more, I'm thinking of swapping for Rallye wheels).
14 x 5-1/2" with P205/70R14 works very well on the '60-'62 cars.
PostPosted: Mon Nov 21, 2005 5:00 pm
Actually SBP Rallye wheels didn't come out till 1970
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Nov 22, 2005 9:05 am
Many thanks, gentlemen !
Irv83
