It is currently Sat Jun 13, 2026 4:43 pm
 Post subject: Take a guess!
PostPosted: Mon Nov 21, 2005 10:14 pm
Just won this on eBay. Guess where it's from! (Not Australia)
PostPosted: Mon Nov 21, 2005 10:20 pm
Sweeden?
Whoa, stock reverse valve body? Or is that just a linkage trick?
PostPosted: Mon Nov 21, 2005 10:26 pm
Not Sweden.
And no, the valve body is not reverse-pattern, and the linkage is ordinary. That's a clue!
PostPosted: Mon Nov 21, 2005 10:38 pm
Found the ebay auciton.. South Africa.
Still don't get the reverse pattern... mirror trick?
PostPosted: Mon Nov 21, 2005 11:05 pm
Well if it's right hand drive I'll bet it has some funky linkage to get to the left side of the trans...
'62 Plymouth Savoy Wagon
'64 Chrysler 300
'47 Farmall H
Merlins are cool
Radials rule
Jets drool
PostPosted: Mon Nov 21, 2005 11:44 pm
Good catch, looked a little closer at the picture and theres a hint of the steering wheel at the right side.
PostPosted: Tue Nov 22, 2005 6:05 am
I was going to say Holland, but S. Africa sounds even better.
PostPosted: Tue Nov 22, 2005 11:50 am
Heyyyy, that's cheating! Image
Nope, it's a right-hand-drive car. Steering wheels' on the right side of the car, gearstick is on the left side of the column.
PostPosted: Tue Nov 22, 2005 11:55 am
Different trans case and valve body; the shift controls are at the RH side of the trans.
PostPosted: Tue Nov 22, 2005 9:37 pm
Pretty cool. Are there any sources of information on these cars?
PostPosted: Tue Nov 22, 2005 9:49 pm
i thought that was argentina's car. they have reverse seasons, reverse success with carburetor brands, their rivers flow the wrong way...
God took you away, then brought you back to me.
PostPosted: Wed Nov 23, 2005 7:55 am
Well, there's this brochure... ;-)
The South African market had an interesting mix of North American-design and Australian-design Mopars. The Valiants were mostly North American-type until the mid '70s, when Australian designs came along, but still equipped with the slant-6 engine rather than the Australian Domestic Market Hemi-6 unit.
A friend of mine in Cambridge, England moved there from South Africa. He has a (deep breath here) 1973 Chrysler Valiant Charger 190 Sports Coupé. That is a rebadged 1971 Demon with the following factory specs (some mods have since been done):
-Right-hand drive
-Floor-shift automatic
-Bilingual controls and displays (English/Afrikaans)
-ECE 3-point seat belts
-Factory 2bbl 225 engine w/remote-mount oil filter on bracket welded to valve cover since clearance needed for steering box
-Amber sidemarker lights front and rear
-White front reflectors
He has a book buried somewhere in his office that describes the history of the South African Valiants, but he hasn't seen it since he showed it to me when I was there over a decade ago. I should pester him again...
PostPosted: Wed Nov 23, 2005 11:18 am
What sort of 2bbl setup? Anything like the bbd supersix ?
PostPosted: Wed Nov 23, 2005 12:03 pm
Carter BBD with integral automatic choke. That is: black round bakelite housing on the outside of the air horn; steel heat tube passed through the exhaust manifold on an extra-tall #2 runner—same exhaust manifold and heat tube used in 1960-'69 Canadian-market 1bbl slant-6s with the optional carb anti-icing system, and all 1969 North American-market passenger car slant-6s got that same anti-ice system, see Here.
Intake manifold was a non-EGR item, but aside from that substantially identical to the intake used in the North American '76-'81 Super Six setup.
Air cleaner was plain flat/round kind (no snorkel).
Camshaft is same as US '71-'80 item (244°/244°/26°)
