It is currently Fri May 08, 2026 7:48 pm
 Post subject: Battery cable routing
PostPosted: Sun Nov 20, 2005 10:43 pm
I am wondering where to route the battery cable for my trunk mounted battery. I want it to be NHRA legal. Can it pass through the passenger compartment? if I route it under the car its close to the fuel line on the passenger side and it seams that is would be close to exhaust on the drivers side. I would sure like to see some pictures of your trunk mounted battery installation.[/img]
1966 Signet
Turbo Slant Six
PostPosted: Tue Nov 22, 2005 7:50 am
Mine goes from the battery to the kill switch, then through the floor, along the frame, and up to the starter. I believe it can go through the passenger compartmment, but you need a kill switch in the posive cable for it to be legal. :shock:
PostPosted: Tue Nov 22, 2005 12:05 pm
"legal" as in "track-legal" or "street legal"?
-dave
what part of "illegal" is so confusing???
PostPosted: Tue Nov 22, 2005 1:53 pm
Car Model: '23 T-bucket
That would be NHRA track legal. I doubt there's any regulations concerning the battery cable routing for the street. There would be some for fuel, exhaust, and brake line routing, though.
NHRA requires a master disconnect, mounted on the rear-most part of the car, whenever the battery is relocated from stock. It must be left-for-off, or push-for-off, and may not be of a keyed type. Must also be labeled
Roger
PostPosted: Wed Nov 23, 2005 12:08 pm
NHRA also requires that the battery either be in an approved box or the trunk has to be bulkheaded from the passenger compartment. Kill switch also has to be clearly marked.
PostPosted: Fri Nov 25, 2005 6:45 am
does the NHRA have any ventilation specs for the batt?
-dave
PostPosted: Sun Dec 04, 2005 8:24 pm
I have some surface rust to clean up and paint.Image
1966 Signet
Turbo Slant Six
