It is currently Tue Nov 10, 2026 11:10 am
 Post subject: 3spd/4spd bellhousings
PostPosted: Fri Dec 02, 2005 5:23 am
Is there a difference between a 3 pd and a 4 spd /6 bellhousing??/
any casting numbers that would be relevant for either or both appreciated if anybody has a library?
thanks for your time :D
dont compromise customize
boost IS a substitute for cubic inches
PostPosted: Fri Dec 02, 2005 5:58 am
Yes there is a difference. The only factory 4 spd /6 BH was cast iron in 64-65 and the alum od BH from around 75-85? Read the article on the home page of this forum.
PostPosted: Fri Dec 02, 2005 6:16 am
thanks
 Post subject: Yep...
PostPosted: Fri Dec 02, 2005 9:08 am
The bolt pattern on the back is different (one of the "ears" changed on the drivers side).
Most 4 speed bells have mounts for both 3 and 4 speeds, the 3 speed bell is strictly for the 3 speed only...
