It is currently Sun Jun 21, 2026 10:41 pm
 Post subject: Slant Six Six Pack
PostPosted: Thu Dec 01, 2005 2:50 pm
CharlieS and I found this at the Turkey Rod Run in Daytona over Thanksgiving weekend.
The manifold appeared to be made of steel and painted with a can of hammer tone gray.
The carbs were some kind of Holley 2bbl.
The ehx manifold was changed to a side exit and the heat riser was eliminated.
I don't think you'll break this motor mount!
Here's the rat rod it was in, looks to be an old Dodge truck cab.
Slant Cecil
PostPosted: Thu Dec 01, 2005 3:34 pm
Way too cool! :D
Thanks for posting it Cecil. :shock:
PostPosted: Thu Dec 01, 2005 5:17 pm
Man, I like that a lot. I've done something similar with Carter/weber carbs to go into my 51 Plymouth.
PostPosted: Thu Dec 01, 2005 6:33 pm
Those multicarb settings look absolutely stunning. Almost makes me wish I'd gone with something like that instead of the turbo/EFI route, just for the visual impact.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Dec 02, 2005 4:01 am
Why not do both? :D
Tom
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
PostPosted: Fri Dec 02, 2005 5:37 am
WOW! pretty slick looking! wonder how it runs?
-james
PostPosted: Fri Dec 02, 2005 5:47 am
WOW!!! :shock:
that slant&rat setup looks stunning!
man, did you use that 6 pack pre-setup that showed up on ebay some time ago? the plenum is completely opened? I mean, did you weld some separator between carbs or the 3 carbs goes to a common plenum and then to the base of those adapters? I really lookmup to your work there.
Juan Ignacio Caino
PostPosted: Fri Dec 02, 2005 7:04 am
Why not do both? :D
Tom
They'll definitely be other projects. :) I'm thinking that at some point I may go and put independant throttle bodies on my Dart.
PostPosted: Fri Dec 02, 2005 8:59 am
Both setups look spectacular slant6rat. I would love to hear more about your setup, and when you plan to start selling the kits (you are gonna offer them to the board soon aren't you :wink: ). I still have this concept that I would love to create a 6,6,6 Demon and think that long air cleaner would look cool with engraved flames in a black engine compartment with airbrushed "real flames" coming out the sides of the hood. Ah if only I had to much money and time on my hands to get the pieces together.
Brian
PostPosted: Fri Dec 02, 2005 9:24 pm
I started out with that crazy steel triple setup I got off Epay. Near as I could figure the pattern was for the big Rochester carbs, which I didn't want.
I already had the Carter/Weber carbs I had planned to use on my Ply flathead motor but got a wild hair and decided to use the slant just to be different. So the result had to be a plenum to make them work.
The plenum is attached to the the intake plates. My NOS bungs will be as close to the intake ports as possible.
Anyway, its different and thats what I like. No plans to compete with Clifford or Offy on the intake.
I have some more pictures here: http://www.picturetrail.com/elplymino
 Post subject: Really nice!
PostPosted: Sat Dec 03, 2005 7:10 am
Those intakes are really incredible, very heartwarming to see serious rodding going on with the old slant/6. I am very interested in the one going in the 51 Plymouth. I'm in the early stages of getting one into my 50 Plymouth Suburban wagon. I'd like to trade info/questions with you on that install. I went with a Clifford intake, 2bbl carb since I had it on the shelf, and a stock exhaust with high temp coating. I went with the slant/6 from having had so many over the years and always liking them. It fits the style of the wagon and gives me all the bells and whistles, power steering, ac, electronic ignition etc.
PS I build disc conversion kits for that 51 Plymouth if you need one.
Life is good!
PostPosted: Sat Dec 03, 2005 9:51 am
Also note in the first pic, the adapter for the 727 trans.
Slant Cecil
PostPosted: Sat Dec 03, 2005 11:03 am
Cool stuff!
My hat is off to all that custom metal fabrication work and long neat "beads" of welding, total skill and craftmanship.
You have to have done some of that kind of work to really appriciate how much time and skill it takes.
PostPosted: Sat Dec 03, 2005 8:46 pm
Thanks for all the kind words.
Doc, good to see you on the board. You hit it on the head about the welding. Thats another story it itself, and to make a short story long, heres the tale.
I've been going to the same muffler shop since the early 60's and asked my friend to weld it up. He's an old time, circle track, early 60's drag racer. He said he could do it(he's got to be pushing 70 by now and still owns his shop), but would rather ask his friend to do it because he owed him a favor and thought he would be able to do a better job. I said O.K. Two days later I got it back as you see it. Free! I am blessed!
Cecil. I noticed the adapter and wondered about the trans he used. And, I apologize for highjacking your post! :oops: I was excited to see work by someone else thats as crazy as me. The nice thing about the Rod intake is the top plate appears to be removable. Its easy to change carbs, add EFI or whatever you want without having to build a complete manifold again, just fab up another top plate. My next intake will have that feature along with longer, straight runners.
olddaddy. I will get a PM to you.
PostPosted: Sun Dec 04, 2005 6:16 am
both of those are cool. very cool indeed.
as for the why dont do both comment. look at this link. it is overseas. but a turbo slant six with triple dellarto sidedrafts. says he puts 564 hp to the pavement. http://marko.salmi.emdia.fi/customers/cust6.htm
congrats. there is a 32 ford roaming around here with a slant in the front. it gets alot of looks .no turbos or anything but definatley different.
dont compromise customize
boost IS a substitute for cubic inches
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
