It is currently Wed Jun 10, 2026 1:48 pm
PostPosted: Sun Dec 04, 2005 5:08 pm
Finally got around to adjusting the valves (with 16000 miles I didn't think they'd be that far off) and car runs much better.....
Before:
Slightly rough idle when fully warmed up (I noticed, nobody else seemed to)
Slight low throttle surge until warmed up
After:
Idle smooth
no surge
peppier
All the intakes were loose;
amount off varied from .001 to .006
....1......2.......3......4.......5......6
(.001, .006, .006, .004, .006, .003)
or
(.011, .016, .016, .014, .016, .013)
Most of the exhausts were loose;
amount off varied from -.007(tight) to .006
(.002, .006, .006, .005, .001, -.007)
or
(.022, .026, .026, .025, .021, .013)
Other than cyl 6, (which I think was a goof by someone since intake and exhaust are the same), valve recession doesn't seem to be a problem
PostPosted: Sun Dec 04, 2005 9:11 pm
So, did you adjust to stock specs, or tighten them up some? I tightened up my intake to .009" and exhaust to .018". Made a big difference according to my "seat of the pants dyno".
PostPosted: Sun Dec 04, 2005 10:02 pm
Stock
I can see the peppy part, as now my cam has slightly longer duration.
But I don't get the surge or roughness (not complaining), as I thought 'tight' valves would cause roughness, and ignition timing & lean carb surge.
As an aside, does anyone know the relationship between duration and lash? How much more duration for a given decrease in lash.
PostPosted: Wed Dec 07, 2005 7:58 pm
Eric, everything is good with the .09 .18 so far? If so I might try that this spring when I change carbs. I just don't want to do anything to put stress on the valves. I have to remember this car is supposed to last long more than its supposed to drive fast.
God took you away, then brought you back to me.
