It is currently Sun Feb 23, 2025 2:25 pm
 Post subject: Flywheel
PostPosted: Tue Dec 06, 2005 2:34 pm
Does anyone make new flywheels for our slants? I have a 23 spline a833 o.d(73 dart sport) and I need a flywheel what can I use?
thanks
PostPosted: Tue Dec 06, 2005 2:54 pm
I think mcleod was going to make a run of performance flywheels. Ask 64dartgt he'll know if they do. What is the intended use stock replacement or race use?
PostPosted: Tue Dec 06, 2005 11:03 pm
Its needs to be able to handle 250 h.p(on a daily basis) and a shot of the gas every now and then!
thanks
 Post subject: Re: Flywheel
PostPosted: Wed Dec 07, 2005 6:07 am
thanks
Remember, the flywheels are different, between the 67 and older and the 68 and newer. The center hole is larger in the later flywheel. You need the correct one to match the crankshaft.
PostPosted: Wed Dec 07, 2005 1:50 pm
I remember,and thanks for the info! Which flywheel is the best,as far as strength goes? I did check mcleoud,they have one but dont give any specs on it,and its 300 $$$ :shock: A little more than I was expecting to pay,so I would like to explore my options!
thanks for the ideas,keep em comming
Users browsing this forum: Ahrefs [Bot] and 67 guests
