It is currently Sat May 03, 2025 1:21 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
 Post subject: carb recommendations
PostPosted: Mon Dec 12, 2005 4:51 pm
I'm replacing the dead Holley 1920 carb on my motor and looking for opinions about what my options are.
Dave
PostPosted: Mon Dec 12, 2005 4:54 pm
What are you going for? Performance or driver? I'm not a fan of the 1920 but they can be rebuilt.
PostPosted: Mon Dec 12, 2005 5:15 pm
Driver. Performance is pretty unattainable with a full size window van.
 Post subject: adaptor
PostPosted: Mon Dec 12, 2005 5:21 pm
Car Model: 1974 W100; 72 Dart
some people over on the .com site have had some luck with using a 1-2bbl adaptor. getting better fuel economy and more umph (which you could sure use in a van!)
beyond that, the carter bbs is the better one barrel in my humble opinion.
having said that, i have a holley 1945 for sale if you need it.
sb
PostPosted: Mon Dec 12, 2005 5:25 pm
Don't sell yourself short. However, for just driver use, I'd rebuild the 1920. DO NOT get a parts store rebuilt carb. You WILL regret it later, when you are stuck w/ a crappy carb and don't have your old one to rebuild properly. If you want to get just a little ambitious, go w/ a two barrel and the a carter BBD.
PostPosted: Mon Dec 12, 2005 5:26 pm
First choice: A new carb (not remanufactured, not rebuilt), either Carter BBS or Holley 1920. I like the design details of the BBS better, in general, but new vs. old in this case generally trumps Carter vs. Holley. (The Holley 1945 is a different story; I wouldn't want one of those in any condition!) If new is not an option for whatever reason, the Carters rebuild and "stay fixed" better than the Holleys as they get on in years, so a carefully-reconditioned Carter BBS would be second preference. Not just a carb kit, I mean a complete recondition job with new throttle bushings, casting surfaces trued, etc. I use the Old Carb Doctor (800-945-CARB) for this sort of work; it costs about the same as a new carb would run if you find one.
I had a few new 1920s, sold most or all of them (might have a few left, would hafta check).
PostPosted: Mon Dec 12, 2005 5:36 pm
What's the story on a 2 bbl adaptor? I am aware of the super six two barrel intake but is there an adaptor for the single intake manifold?
PostPosted: Mon Dec 12, 2005 5:46 pm
Eegads, here we go again.
One word: No. If you want a 2bbl, use the correct 2bbl intake!
2bbl carb-to-1bbl manifold adaptors aren't just a bad idea, they're a really dumb idea. Best analogy I can come up with at the moment: You decide to install really powerful headlamps, but before you use them, you spray black paint on them so they're 50% occluded. Or: You decide to put on a nice free-flowing 2-1/4" exhaust system, but you weld a big washer with a 1" centre hole over the end of the tailpipe. Or: You hop up your engine so it produces 40% more horsepower, and drive around with the parking brake on. Or...get the picture?
PostPosted: Mon Dec 12, 2005 5:52 pm
...... Or: You decide to put on a nice free-flowing 2-1/4" exhaust system, but you weld a big washer with a 1" centre hole over the end of the tailpipe........
But that adds backpressure so you get better mileage and power at lower rpms..........
:P :twisted: :lol:
PostPosted: Mon Dec 12, 2005 7:05 pm
Can a poorly adjusted / burned out carb cause severe overheating? I've got a freshly rebuilt slant 6 with an old carburetor i found lying around and the engine hits 250 degrees going 35 mph. The timing is set, new radiator, water pump, thermostat, all hoses, heater core, everything. Still overheats bad. The way the carb backfires and stutters and not knowing it's age i am going to replace it hoping to solve the heating problem. Any advice?
PostPosted: Mon Dec 12, 2005 8:33 pm
If it's running extremely lean or has large vacuum leaks, yes, it can.
Not good.
The timing is set
How 'bout the cam timing?
PostPosted: Tue Dec 13, 2005 11:59 pm
There's a bunch of guys over at .com that are real happy with the Weber and the adaptor on the stock intake. It seems that the people looking for power don't have much luck with them, but all the guys that use stock slants for economical daily drivers rave about the weber/convertor/single intake. I have an old truck, and all I want is something dependable that is cheap to keep on the road.
Good luck.
I am suprised that someone didn't yell and scream at you to do a search. I guess there is no more information on the topic and anybody that doesn't adhere to the collective mantra need not share.
:idea:
1967 D100 /225
Some of us catch on slow, and some of us don't.
PostPosted: Wed Dec 14, 2005 2:27 am
:roll:
Good luck.
Luck doesn't enter into it so much as thought and horse sense.
Your snarkiness is uncalled for.
PostPosted: Wed Dec 14, 2005 7:01 am
When it comes to size, how does the DGAV compare to a BBD? If it's closer in size to a BBS, I could see it working with an adapter.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Dec 14, 2005 11:22 am
You shouldn't flame a new guy about the search feature. All it needs is one gentle mention. p.s. I don't have the right to flame anyone about searching since I ask without searching all the time.
Users browsing this forum: Ahrefs [Bot] and 10 guests
