It is currently Mon Nov 16, 2026 11:49 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
 Post subject: Re: mine, too.
PostPosted: Wed Dec 21, 2005 12:45 pm
[quote="mpgFanaticThe torque shaft arm ripped off the tube; I created a reinforcing strap and had my local muffler shop weld it on. I'm guessing that the failure is just a factor of metal fatigue after 40 years of use. Even with a wimpy clutch spring, that's still an awful lot of stress on those welds on the tube.- Erik[/quote]
Yep, that's exactly what used to happen to mine and the car was at most 7 or 8 years old at the time. The first couple of times that it happened I just went to the dealer and bought a new one. The last time I found some large steel washers and ground out the centers so that they would fit over the tube then I pushed everything into position and welded the washers to the tube and arms. Problem solved, it never broke again.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
