It is currently Thu May 28, 2026 12:01 am
Post new topic  Reply to topic  [ 49 posts ]  Go to page 1 2 3 4 Next
 Post subject: air cleaner
PostPosted: Sat Dec 24, 2005 8:05 pm
ok i want to use a bbd as a carb but i want to use an open element air cleaner assembly.
what other carb fits the stock 2 bbl intake (point me to an adapter if needed) so i can use an aftermarket filter assembly.
 Post subject: Re: air cleaner
PostPosted: Sat Dec 24, 2005 8:40 pm
Why? They're not better, they're worse.
PostPosted: Sat Dec 24, 2005 8:47 pm
thank you so very much
instead of just simply answering my question u would rather question it and probably shoot it down
i like the way they look
just want to bring a lil polished alluminum to the engine bay
sorry to be an ass but geez
PostPosted: Sat Dec 24, 2005 9:07 pm
You are more than welcome.
sorry to be an ass
Apology accepted.
 Post subject: summit
PostPosted: Sat Dec 24, 2005 9:08 pm
Car Model: 1974 W100; 72 Dart
summit has the one you are looking for, just measure the diameter of the BBD. go to summitracing.com and do a search for air filter.
i don't have a bbd here or i'd cut and paste a link. anyway, hope that helps.
sb
PostPosted: Sun Dec 25, 2005 9:08 am
Buy one that fits a 318 two barrel. It i sthe same diameter as the slant six BBD two barrel. Just about every aftermarket two barrel air cleaner I have ever seen will fit the BBD neck. These should be readily available at any auto parts store for less than $20.
PostPosted: Sun Dec 25, 2005 9:15 am
I use an Edelbrock Pro-Flo from Summit Racing. It fits the BBD and stock slantsix element and clears the hood on my 65...a big deal for early A Super Six applications.
PostPosted: Sun Dec 25, 2005 10:33 am
thank you
i appreaciate the help
dustin
PostPosted: Sun Dec 25, 2005 10:46 am
Mr. Gasket also makes an adapter so that you can use any of the larger throat air cleaners on the smaller throat carbs (or vice-versa if you wanted to for some reason). It does add about an inch of height.
PostPosted: Sun Dec 25, 2005 1:53 pm
Or if you REALLY couldn't find a two barrel air cleaner you could make an adapter out of plywood. It wouldn't add any height.
PostPosted: Sun Dec 25, 2005 2:32 pm
Wood? Plastic or some sort of composite maybe... wood would be a bad idea as it might ignite under backfire.
PostPosted: Fri Dec 30, 2005 7:11 pm
I just purchased a Mr. Gasket open air cleaner assemble from Summit racing. The air cleaner needs to be 2 5/8 of an inch. This air cleaner came with an adapter to fit the carb. It is crome and 10 inch diameter like the stock element it had before. The lid is just chrome has no markings of any kind. Just my two cents worth.
psychodieseltech1348
PostPosted: Fri Dec 30, 2005 10:31 pm
why are they worse, do u loose low end power :?:
Cuda Progress :D
The dart as it sits now :(
PostPosted: Sat Dec 31, 2005 9:30 am
Don´t know why open element are worse, since I´m using one my gas milleage is a bit bitter and my mix is much rich, less gas I need to use.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Sat Dec 31, 2005 12:07 pm
The open elements are worse for power.
They pull in all the hot air around the engine, while a tube (and even better a tube with extended snorkle) will pull in air from a colder location.
Colder less dense air has more O2 to burn, thus more power.
Users browsing this forum: Amazon [Bot] and 7 guests
